Question about Philips DVP642 DVD Player
Won't power up
The Red Lite keeps flashing on and off. I cannot turn the unit on. I have tried unplugging it. Still no response
Change the largeest cap inside, that will solve the problem.
Posted on Mar 22, 2007
    President:
  • 3,130 Answers
If you already tryed to unplug the unit then you did all you can unless you know how to trouble shoot the power supply with a multi-meter. It sounds like what you described to be one of the switched supplys to be defective., Sorry I could assist you more.
Posted on Jun 14, 2006
SOURCE:
Unit has power bur will not turn on
You need to be specific to get help. Just what is happening? What is not turning on? The compressor? The fan(s).
Is thermostat properly set?
Jun 19, 2016 | Heating & Cooling
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
Red paper light keeps flashing. Closed all doors, turn on and off
Close the front cover. If the error is not
cleared even after closing it, open the cover
once and close it again.
The error may occur because of the laser
BD malfunction. The Laser unit may need to be R/R'd
Try cleaning the Scanner Window
When replacing the drum unit or toner cartridge with a new one, be sure to clean the scanner
window.
1) Turn off the power switch and unplug the power cord.
2) Remove the drum unit from the printer.
3) Gently wipe the scanner window with a soft dry
CAUTION:
· Do not touch the scanner window with your fingers.
· Do not wipe the scanner window with cleaning alcohol (isopropyl).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
cloth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 10, 2011 | Brother HL-2040 Laser Printer
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Red light stays on when powered,won't turn on.
Don't have a solution. Cannot turn red lite off with remote or manual operation.
Oct 25, 2006 | Cyberhome CH-DVD 300 DVD Player
Philips DVP642 DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
