"NO DISC" reading
Š¯ello. Sorry for my English. I hope you understand my problem. My system can not read any discs. Laser works (lights). CD drive is working properly. engine displacement of the laser is not deactivated at the end point (limit switch works fine - closes, but no effect).When I turn off the system - CD drive motor continues to work. You have a great experience, say - need to change the microprocessor?
  • Anonymous Oct 24, 2008
    I have a JVC Compact Disc Digital Audio UX-T55 it also shows "no disc'
    and makes a clicking sound when I press the play button same with the
    cassette and the radio is not very clear.
  • augestrain82 Dec 25, 2008
    the lcd screen shows E. i have tried numerous disks and still nothing
4 Suggested Answers
Kimi
  • 277 Answers
SOURCE: won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Posted on Dec 04, 2005
Dinoza
  • 112 Answers
SOURCE: No Disc error, won't read any CD
Another option is to try a lense cleaner CD, or doing it manually.
Posted on Feb 13, 2007
  • 93 Answers
SOURCE: CD Player Motor & Laser
If motor is NOT spining, laser can't read CD.
Posted on Oct 08, 2007
Why my system eject cd/ dvd and after that i use combinition keys eject+ stop to lock it, it dosen't read the disc and show's no disc in. how i can fix it?
You can't. CD/DVD or even VHS have sensors. Sensors sending information about empty or loaded. Can be laser are broken too. Laser after loaded dick try to read out information from disc, but if no info, device understand like 'empty disk' or 'just no disk'.
You can try to buy CD/DVD cleaning disc for laser clean, but if driver can't find disc perhaps it not help.
Mar 23, 2016 | Audio Players & Recorders
Cd inserted in cd player no disc
The problem is in the laser pickup assembly, overtime the laser becomes weak until it will no longer read the disc, it is far cheaper to replace the stereo than have the old unit repaired.
May 01, 2012 | JVC MX-GT80 Shelf System
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
Trying to copy VHS to Disc-Says"Unknown disc"
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
    if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
    May 08, 2009 | Technics SC-DV290 System
    Deh-15 wont read disc
    hi sounds like the laser is on its way out, you will need a new laser
    www.carradiospares.co.uk
    Nov 24, 2008 | Pioneer DEH-15 CD Player
    Home theater won't start playing DVD
    If a disc will not spin, A- the laser may not be focusing on the disc, as it must do this before it will spin and read the TOC. ( table of contents) B- you could have a fault in the spindle motor circuit or the motor could be bad. You will need to find an authorized servicer if you do not understand solid state repairs. Good Luck PS please dont forget to rate this.
    Oct 14, 2006 | JVC TH-A9 System
    Won't read disc
    Dec 04, 2005 | Aiwa NSX-A115 Shelf System
    81 people viewed this question
     Grubhead
    Grubhead
