Question about Samsung SCH-a670
Not able to talk
I got pushed in a pool with my phone in my pocket. I took it apart & dried it well. Put it back together and I am able to call but can't hear the other persons phone ringing, busy, voicemail or if anyone answers, there is no sound. The same if someone calls me, it rings, I try to answer & nothing. I can send & receive text messages. I am able to hear it ring. When I tried to open the phone, I broke the plastic piece for the headset at the top. It is still in there with the top part missing. Would this have anything to do with the problem. Please help!
  • priyanka807 Jul 08, 2008
    hi ,my sprint sanyo phone suddently stopped working properly.i can hear the the incoming calls ,even i can hear the person on line but no one can listen me......i m wondering wat could be the problem.if any one have a solution for this please tell me.
  • Anonymous Mar 22, 2014
    There is a symbol at the top [phone receiver with red line diagonally across it] that I've never seen. Phe rings and person can hear me but I can't hear them. Also, cannot make calls!!
  • 513 Answers
You might have severed a wire that's connected to the phone's speaker. You were very lucky to save your phone as much as you did. I don't think there's anything you can do yourself, but you probably won't have to replace the whole thing, if you find a cheap place to service it. Just some minor work. I find this one of the main problems with living with celular phones these days, you can't push people into a pool anymore. If anyone comes up with a waterproof Cell phone, that person would be a milionaire ;] Good luck!
Posted on Jun 15, 2006
My sons Samsung E2121B was left in his pocket and ended up being washed. I took it apart to dry it out but, when i put it back together and just turned it on a blue screen just appears and flashes. Can...
Opening the phone ON was a mistake!
Remove battery and sim and place it (open) in a bowl full of rise (uncooked of course).
Leave it there for 15 hours minimum.
Rise have the ability to absorb humidity.
After that, test it.
Other possibilities are to use below product (or similar ones):
http://www.getgadgetgenie.com/
Jul 29, 2011 | Cell Phones
C902 swiming pool!:(
To be honest, the phone is probably fried. BUT.. If you want you can try to take the phone apart and use and old tooth brush with some water and just scrub clean the inside of the phone, circuit board and all. Wait for the phone to dry and then put it back together. What this does is it takes all the chlorine that dried on the circuit board and it removes it. I have done this before myself, and I got my phone to work. So it is possible but see what you can do.
Jul 09, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
LG VU GOT WeT!!!!!!
Ok. Heres what happened to me:
I forget my LG Vu (CU920) was in my pocket and I jumped in the pool. I was in the pool for about 10 minutes before I realized. It was full of water. I took the battery out as soon as I realized it. HERES HOW I FIXED IT!!!!!!!!!
Step 1- I took it home, removed the screws on the back panel, and removed it. Now the entire back casing was off.
Step 2- I put the phone and battery (separate) in a bowl of uncooked rice. Sounds crazy but this absorbs all of the water. I left it in there for 2 days.
Step 3- After 2 days, I put the battery back in and everything turned on. Only problem was there was a big bubble in my LCD screen. I then took the phone apart further by popping of the front casing of the phone. I then try to get underneath the LCD to air it out, but I accidentally broke the LCD screen (inside the phone...not plastic outer screen).
Step 4- I went online and purchased a new LCD screen for around $40 from a cel phone parts website. I got it and installed it which was not too hard. You just have to remove all the visible screws (i believe there are 6) from the back side. Then pop off the front cover and the rest is pretty obvious.
Step 5- Put it all back together and it all worked again!
Step 6- My battery soon died after of all this...Im guessing from the water damage. I bought a new one online for around 20 bucks. Now the phone is good as new.
All in all spent 60 bucks and revived the Vu from water damage!!!!!!!!!
Jun 28, 2009 | LG Vu CU920 Cellular Phone
Water
Sometimes when electronics are dropped in water, you can still use the. Circut boards have a silicon coat over the circut boards for instances like this. Depending on how long it was in the water, you may be able to still use it. Let the phone dry out for about 24 hrs (take out battery and back cover) then try to replace the battery and start it back up. If it doesnt turn on the circuts were affected and it broken.
Jun 24, 2009 | LG Vu CU920 Cellular Phone
Everything works but the touch screen.
caring for the touch screen includes touching the screen with clean and DRY hands., if your phone fell in the water, it will likely damage the touch screen.. contact your nearest LG repair center.. i hope your phone will soon be fine..
May 01, 2009 | LG Vu Cellular Phone
Palm Centro AT&T got wet;
http://www.fixya.com/support/r3771170-phone_water_damage
Jan 24, 2009 | Palm Treo 500 Centro
Not able to talk
have the phone check fully the microphone needs to be replaced and the earpiece as well........the housing by the earpiece might be block so take a small flatbit screwdriver and have try to to clear it.
Nov 06, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Wet dash
There's still water in it. You'll need to take the battery out and let it dry another two days. I got my phone wet one time and it took a week before it worked again.
Oct 15, 2007 | T-Mobile Dash Smartphone
Samsung SCH-a670 Logo
399 people viewed this question
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
