Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door needs assistance to open all the way - Chamberlain Liftmaster
Have a Chamberlain Liftmaster. When the remote button is pushed, the door will go up about one foot then stop. Sometimes it will go all the way up on the second try. Some times it takes several tries. Sometimes it won't o up at all unless I help lift it up.
  • dennishuns Dec 21, 2008
    Motor runs ,but only lifts door occasionaly
  • rbrovold Dec 22, 2008
    this only seems to happen to my sears gdo when it' very cold. It will go up about a foot and stop. It takes multiple attempts to get it to open all the way. My springs were just replaced a year or so ago.
  • 77 Answers
Watch the door go up and down to figure out the problem, but it sounds like a problem with the springs. We have had similar problems with our garage and it is usually because one spring has more tension on it than the other so when it tries to go up one spring pulls more than the other and the door gets wedged on the rails. I have found this usually occurs when the springs get older and they usually break a short time later. The best solution I have is to check and possible replace the springs.
Posted on Oct 19, 2008
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
My remote opens my garage door but will not close it. It starts to make a clicking sound when the remote button is pushed to close the garage door. It is a chamberlain Liftmaster with wireless key pad....
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flashing. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to re-program a remote, battery needed to be replaced for a remote garage door opener chamberlain 1 2 hp garage door opener PD610D
THERE IS A SQUARE BUTTON ON THE END OF THE UNIT. PUSH AND RELEASE THEN PUSH AND HOLD THE REMOTE BUTTON FOR ABOUT 20 SECONDS. THE NEXT TIME YOU PUSH THE REMOTE THE DOOR SHOULD GO.
HOPE THIS HELPS
Aug 05, 2009 | Liftmaster, Chamberlain, Sears Door...
Change code on keypad for model 61WD liftmaster garage door opene
is it little buttons on the remote change the buttons on the back of your operator to the same has the ones inside your remote. or if it's a newer one you can hold the square button of the back of the operator in for 8 secs. then after that you push the button and let go and then push the button on your remote. done
Mar 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 724LM Pug-in Light and Appliance Control
does it have a learn button. push it and push remote button.
May 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
