Since I just solved this for someone else, here's the link to the manual. Under HOME and WIRELESS tabs, your info is displayed. This is for a rev C manual. If you need an A or B manual, just tab back and get it, but the procedure should be the same. Look at the FAQ items at the bottom for SSID.
http://support.dlink.com/products/view.asp?productid=DI%2D514%5FrevC
Carl
Wow. Had you clicked on the link above and looked at the 3rd FAQ regarding PASSWORD, you would see how to log into the router and what the default username and password is. How about this? http://support.dlink.com/faq/view.asp?pr...
By default the router is 192.168.0.1 which is typed in the URL line. You then log in with admin and no password. That's the default, so if someone has changed it, you need to go to whoever set it up to get the proper password, or use the tab of FAQ's that resets the router.
You say log in to your router - how do I do that? Sorry, I am a novice at all of this.
If you log into the router, the code is displayed under Wireless setup.
