Question about Philips 27PT6441 27" TV
Picture problem The color on the tv goes in and out all the time. It goes from being right to going really dark and then light. I have tried many things like replacing the cable that goes to the tv to a expensive cable that is supposed to be excellent. The tv is only about 4 or 5 months old and I am ready to throw it out... please help me try to fix it.
    President:
  • 3,130 Answers
It sounds like to have a problem in the video circuit or the Hi voltage circuit. If you know how to fi8x electronbics then get a meter and monitor the b+ on the crt drivewr transistors. See my point . WQe cant tell you exactly what the problem is and teach you how to read a circuit diagram, and to solder. These sets have a high voltage in them even when they are unplugged so you shouldnt really touch these puppys as there are no user serviceable parts inside these sets and should only be done by a quilifyed service tech!! If its only 4 to 5 months old there should be a warranty on the set so you shouldnt touch it as well just for that reason. You should be looking up in the owners manual for a servicer or # to call to find one to fix it under the warrantee. good Luck
Posted on Jun 14, 2006
SOURCE:
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
Picture color gets really dark after tv has been on for a few hours
try going to irst time set up an restart verything over that works everytime
Nov 19, 2012 | LG 55LH40 55 in. LCD HDTV
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
JVC 27" TV
Adjustable Color Temp. The Adjustable Color Temperature feature lets you adjust the color balance on your TV, depending on the type of light in the room, such as direct sunlight or artificial lighting. On your remote control there should be a button that lets you change the picture mode, IE. Rich, Personnal, Cinema, Sport etc...
Feb 21, 2008 | JVC AV-27D305 27" TV
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Philips 27PT6441 27" TV Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
