Toshiba P100 JR1E will not boot at all.
I bought a Laptop for my wife and she said it was doing a self bios update and half way through it went dead now it won't boot at all. I replaced the nVidia 7300 go with a 7600 from the same model and it still won't boot. All I get is a black screen and the hd lite flashes 3 times and stops.. I paid 2500.00 for it from London Drugs and as a result of them being " it has to be user error" and not taking responsiblity for their products. So now I need to Know how to fix it with out selling my first and possibly second born.
  • 4,338 Answers
When doing a BIOS update, known as a firmware update, the process should never be stopped. But your wife has learned that.
What you need to do is go on the web and find the latest firmware update onto a bootable cd and install it. When you install a firmware update, you need to have the AC adapter plugged into wall socket.
You should be able to find the firmware update at Toshibas' website.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
Toshiba Satellite A200-FE008C bios update failed
You can't. The mother board is now dead. You will need a new bios chip.
Jan 22, 2014 | Toshiba Satellite Pro A200-EZ2204X...
TOSHIBA p100 LAPTOP SREEN DEAD AFTER BIOS UPGRADE
Purchase a new EEPROM with a good BIOS loaded. I suspect the anti virus programme was not disabled and has stopped the new firmware from loading, leaving a corrupt EEPROM.
Mar 23, 2013 | Toshiba Satellite P100-429m Laptop DC Car...
Hi I have a toshiba satellite laptop with a 17"
Have you tried to connect an external monitor to see if the thin line is still visible? If not, you can try it but if you do not have an external monitor, you can just access the BIOS (Basic Input Output System) by pressing F10 or Del (whatever key is designed on your laptop to access it) and check if still visible. If it is visible in the BIOS, you may need to replace the LCD inverter or the LCD of your laptop. However, if it doesn't appear in the BIOS, you can try to update your video card driver.
Hope this helps.
May 27, 2011 | Amstron Toshiba Satellite P100-429m Laptop...
Bios Faile
bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Aug 01, 2010 | Toshiba Satellite P205D-S8804 Laptop
M laptop is toshiba L500.i was updating the bios
if it is in warranty go to the service centre otherwise it must be bios replaced by prof.
Jun 25, 2010 | Toshiba Satellite L500 Series Notebook
I updated the bios for my packard bell easy note laptop, model L4014. The laptop now just boots and reboots. It seems to have lost my drives. How do I resolve this problem
go into your bios and have a look at your boot order, when you do a bios update, usually it sets bios to default setting, most of the time making dvd drive 1st boot rather then hdd.
might help.
Jan 02, 2010 | Packard Bell Easy One Silver 2101 Notebook
Toshiba laptop P100-ST9612 majors problems--NOT fixed by Toshiba.
oooo man that ones a doozy, if its the one with the go9700 video card its a pretty bad model. the card brand new is 700+ from toshiba. i have run into that problem quite a bit.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
I want to format my hdd and re install oem. how do i format on p100
Your Laptops comes with recover disks ,Insert the disk,boot the laptop from the recovery disk.It will format your laptop to its original state.
Good Luck
Siju.D
Nov 05, 2009 | Toshiba Satellite P100 Notebook
Beeping then shuts down.
Hi Speedport!
This isn't something as simple as a dead / broken / malfuctioning battery is it ? Try removing your battery, plugging the laptop into the mains and running it idle. The Bios update you found may have been a coincedence...
David
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Jan 11, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
100 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
