Require region unlock code for LG RC389H - Televison & Video
  • 376 Answers
1.Switch on unit
2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
Posted on Oct 19, 2008
2 Suggested Answers
jaffa012001
  • 376 Answers
SOURCE: unlock DVD region code for
Press the HOME button on the remote, go to Setup and select Start. From the TV options go to TV Aspect and highlight the 16:9 Wide option (must be 16:9 0ption). Now enter 1397139 using the number keys to access the system configuration information.
To change the values of these options hit the ENTER button and then use the left/right arrow keys to select OPTION 5. Change it's current value to ff using the up/down keys. Now power off with the remote and then power back on. Your recorder should now be region free. To check go back into the system configuration information where Region Code should now be 0.
Posted on Aug 13, 2008
Activate secam option
The recorder is not SECAM compatible - can't be selected.
May 13, 2017 | LG RC389H DVD/VHS Recorder
I have an LG VCR/DVD unit model RC389H purchased in 2010 When I try to play a DVD from France (Region2) I get the message "Incorrect region code. Can't play back" There doesn't seem to be a...
Take a look at the back of the unit. You'll either have one of these: captainhawk1.gifcaptainhawk1_0.gif(You may have another number)
Or one of these: captainhawk1_1.gif (or the oblong version... I just couldn't find one of those)
If you've got one of those little globes with the number on the back of it, you have a region locked DVD player and what that means is that the seller is selling locked DVD players and using a hack to get into the system and change the region code. They just did a sloppy job. What caught my attention is the fact that this is PAL Dvd Player and you need a separate NTSC converter to play on use television. A true ALL Region DVD player would also have be able to play both PAL and NTSC without the need for a converter as it is built-in already.
DVD's are not only made with region codes they are also made based on the analog standard for the region they are sold in. The US uses NTSC, Europe uses the PAL standard and what that means is that it's a different technology to broadcast the signal onto the screen. The US has been using NTSC since the 1940's, I'm not really sure about PAL. Take a look the back of a US DVD case and you'll notice atthe bottom it will say NTSC.
Since ALL Region players are obviously more desirable and therefore a true ALL Region player would be more expensive, it has become a common practice for sellers to get the region locked-players from gray market sources in Asia and use hacks to make them ALL Region but as noted it still doesn't solve the issue of the analog standard so you ahve to get yourself a converter. Think about it: what would be the point of LG making an All Region player that couldn't broadcast both analog standards?
Now, if you do have a globe with an ALL on it, then you have a true all region player and shouldn't have an issue on an NTSC television, but on the other and, it wouldn't play Region 2, so you obviously have a problem. So, either you got completely scammed or you have a true ALL Region player that is defective. Either way, I'd return the thing.
If you're interested, here are some hacks for that particular machine: http://www.videohelp.com/dvdhacks/lg-rc389h/9189 http://answers.yahoo.com/question/index?qid=20080928062502AA9Jzua
May 04, 2011 | LG Televison & Video
How can a disc recorded in Canada be played on the RC389H ?
Here is how to make your lg RC389H DVD player region free, and allow it to play region 1 discs.
Mar 11, 2011 | Cameras
How do I get an owner manual for this product?
its here for free, available in pdf format will need adobe acrobat or similar.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/RC389H-_E
please rate :)
Feb 14, 2010 | LG RC389H DVD/VHS Recorder
Anyone got the code for changing the area code for a LG RC389H video combo unit
If you mean to play DVD’s that you may have purchased in another country the see below
For that you need to do a Google for "mymodel region free" or "region free hack"
Not all DVD players are capable of this often very simple modification that many manufacturers build into DVD player. (Usually just involves the remote control and a combination of keys)
Your search will turn up a lot of sharks that want money for the hack (fix)
IGNORE THEM
There are a lot of sites where the information is free.
If after opening up the region free parameter you still have issues and you still want to play your dvd's from around the world you might want to consider another one
I am STILL (lauren) unsure of FIXYA's policy on this topic and am awaiting further clarification on the issue with regards to handing out these codes as this is not HACKING in the same sense as pirate software etc. it is just enabling an extra feature that the manufacturer provided.
I would prefer not to get my @ss kicked. That is why I can only give you the search terms rather than site links or specific information
Aug 30, 2009 | LG RC389H DVD/VHS Recorder
Followed instructions to unlock LG RC389H - told to press "OxEO"
I had the same error but did a hard shut down and reboot at the player instead of the remote and went back in and checked my configuration and had region 0
Jun 22, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
please donot forget to rate this solution.
Thanks for using FixYa.
Jan 28, 2009 | LG RC199H DVD Recorder/VCR
Unlock DVD region code for LG RC389H
Jul 25, 2008 | Televison & Video
Unlock code
LG DR275
Two solutions for this one,
For older models try:
1. Power on and open the tray
2. Press Setup
3. Highlight but don’t select the lock icon
4. Enter: 0,0,0,0,0,0 and 0 (seven zero’s)
New models require a little more work try:
1. Download the following file (user: dvd pass: unlock)
http://www.dvd-unlock.co.uk/dl/lg5000.zip
2. Unzip the downloaded file.
3. Burn the folder called �RMTM0000� to disc.
4. Power up your DVD player with the new disc and you should be presented with a region change menu, use 0 (zero) for region free.
Dec 27, 2007 | Televison & Video
Televison & Video Logo
783 people viewed this question
Top Televison & Video Experts
