Question about Microsoft Xbox 360 Console
No signal error
I now get a message -- no signal - when i turn on the xbox 360. The unit was working fine just the other day. Turned it on yesterday and now get this message. I have tried changing the cables out and still no signal.
Any ideas???
  • garrettzuver Oct 20, 2008
    when i turn on my xbox360 it runs fine but my tv says no signal and i have tryed 2 different tv's and nohing will work,please help.
  • 77 Answers
If you've tried different cables, then it is something wrong with the video card and you should call 1-800-4my-xbox. almost all xbox 360s are in warranty with them and although it is a pain to deal with them, its the easiest and cheapest solution. Unless your extremely good with electronics and computers I wouldnt open the case because that would void the warranty if there is one.
Posted on Oct 19, 2008
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Hi, I've had my xbox 360 elite console for
might want to check the cable, if you are not getting light from the xbox360 most likely you have changed something on the TV. make sure its on the right setting
HDMI device has to be on first in some cases.
make sure the plug is good and well connected.
restart the xbox360 and try again.
try the xbox on another hdmi device to see if it working.
or try the regular mode of the xbox.
May 26, 2010 | Microsoft Xbox 360 Elite Console
Xbox 360 q1 and q2 lights going red
i dont now because my xbox 360 do the same thang
Apr 21, 2010 | Microsoft Xbox 360 Console
Xbox one blinking red light.. 1 not 3,, first time i seen this, fixed many ps3 ylod,, is it the same fix? looking for help here or a good link on repair info
When you get one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
Feb 06, 2010 | Video Game Consoles & Games
Disk unreadable but clean disk not scratached
http://www.youtube.com/watch?v=iOmNtrStDgM
Turned on your Xbox 360 console one day and and when you try to play your game you got the message "This disc is unreadable" OR "Unplayable disc".....??
First determine whether it's a fault with the disc or not, by having a look on the disc itself & make sure it's not scratched and there are no flaws even on it, and try other game discs on your Xbox 360 console .
If your disc is scratched or have flaws try putting other discs in your Xbox 360 console just to make sure it's the disc not the actual console causing the error, If other disc are working fine, refer to the scratched discs page on our website to know what are the steps you have to follow to get it sorted out.
If the disc is not scratched and doesn't have any flaws on it, cleaning the disc and trying it once more may solve the issue, if that doesn't work try to check it by putting other discs in your Xbox 360 console, if they all work that would be definitely a fault with the disc itself and in a case like this you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "This disc is unreadable" OR "Unplayable disc" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Jan 03, 2010 | Microsoft Xbox Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 turns on somtimes
open the xbox and fix the faceplate yourself and try getting a new power cord or a new powerbrick
System error it says. a red line appears at bottom left of the console green light. A messege appears with black backround telling me to contact customer support what do i do to fix it?
This problem is typically caused by a hardware failure. Turn off your Xbox 360 console, disconnect and then reconnect all cables. Turn your Xbox 360 console on again. If an Xbox hard disk is attached to your Xbox 360 console, turn off your Xbox 360 console, and then remove the hard disk. Turn on your Xbox 360 console, and then test for the error message. If you don't see the error message, turn off your Xbox 360 console, and then reattach the hard disk. Alternate testing with the hard disk attached and removed to see whether the error message occurs only when the hard disk is attached. If an Xbox Memory Unit (MU) is plugged in to your Xbox 360 console, turn off your Xbox 360 console, and then remove the memory unit. Turn on your Xbox 360 console, and then test for the error message. If you don't see the error message, turn off your Xbox 360 console, and then reinsert the memory unit. Alternate testing with the memory unit inserted and removed to see whether the error message occurs only when the memory unit is inserted. If you continue to experience this problem, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Oct 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
