Question about Hitachi 43GX01B 43" Rear Projection Television
BAD PICTURE LOOKS LIKE THE GREEN "GUN" NOT REALLY SURE IF THATS WHAT ITS CALLED ISNT ALIGNED PROPERLY TRYED CONVERGENCE ADJUST GREEN LINE IS WAVY AND IRATIC ALSO HAS GREEN SHADOWS ON PICTURE
  • pmcmahan Aug 18, 2008
    I have a convergence issue with a hitachi 65swx20b Blue will not realign...what part do I need to replace I have some tech experience but no information on hitachi's.
    thanks
    President:
  • 3,130 Answers
Well the green gun is whats inside the green picture tube or crt(cathode ray tube).. Irt certainly sounds like you have a problem with the convergence but the only way to tell for sure is put on a full cross hatch pattern like the one thats used for major alighnments such as after a tube is replace. This problem you have is probably the convergence IC and the part dosent unplug or come out easyly as there are no user serviceable parts inside this set. It should be left up to the service station for the manufacturer. Not alot you can do unless your a tech . Sorry Good luck
Posted on Jun 14, 2006
SOURCE:
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
Intellesence cant correct wavy color ghosted images on my screen. attempted to manually adjust and line up the colors blue will adjust but red will not.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 25, 2010 | Philips 60PW9383 60" Rear Projection...
Wavy line goes through picture during color changes,picture cut off on bottom
*Screen Looks 3-D
*Colors wont align
Apr 25, 2010 | Hitachi 60SBX78B 60" Rear Projection...
Can not adjust the convergence green lines will not line up properly.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
The screen is wavy when I'm looking at an on screen menu or there are words on the screen. Just wondering on how to fix the problem. Not really bad but just really annoying
*Screen Looks 3-D
*Colors wont align
Mar 28, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Red arching lines
is this that you are adjusting called convergence? If so then if it's really bad you can try to reset convergence, if not then the red needs to be aligned up with green first then blue on green. Can you provide a picture of what it looks like?
Apr 13, 2008 | Mitsubishi WS-65711 65" Rear Projection...
BAD PICTURE
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43GX01B 43" Rear Projection Television Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
