Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Dell 17 in monitor 4 yrs old green light flashing
Have tried all the obvious, connected it to another processor, changed lead with one that works and cannot get it to work Have connected an old monitor to my system and that works
    Genius:
  • 2,120 Answers
The backlight bulb has burned out. Available on eBay.
Posted on Oct 19, 2008
Wont display anything, green light on power button keeps flashing
The flashing light on the Dell E173 series indicates a failure in the power supply board. This series has several versions on the board so you will need to know the exact model, it is listed on the label at the bottom of the back cover. The versions are E173FPc, E173FPb and E173FPf. We have repair instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ that cover each version on the unit. The repairs will require replacing a few pars that will need to be soldered.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Power light is green But no Raster on screen. Flashes only when I turn machine on or off.
Try the obvious first: make sure the cable from your computer is connected tightly to both the computer and the monitor.
Does your monitor have several receptacles for connecting different kinds of cables? If so, there is probably a way to tell it which one is active; my monitor has a button on the front labelled "Input". Look for something similar (switch, button, etc) and try it. Wait a second to see if you get a response; if not, press it again. If you have 4 plugs on your monitor, you may have to do this 4 times.
If you can tell me more about your monitor (make and model) or upload a picture of the place where the cable connects to the monitor, that might give some clues.
Nov 04, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
My monitor will not turn on
disconnect the monitor cable from your computer tower
if you get a 4 colored box which says power on self test. it means its not the monitor then you have to get the video card or the systemboard.
Jun 09, 2008 | Dell P793 17" CRT Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Dell P780 17" CRT Monitor(3 yrs old) issue
That sounds like a monitor issue, not a video card. Gradual fading means components within the monitor are wearing out. However, I strongly advice against attempting repairs. CRT monitors hold a strong electrical charge. People have been injured and even killed by attempting to work on them without proper tools and training. A 17" CRT monitor is too cheap to be worth the risk (you can often get them used... I got mine for $20 at Goodwill).
Aug 22, 2007 | Dell P780 17" CRT Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
100 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
