Question about Kenmore 15202 Mechanical Sewing Machine
Kenmore 15202 - Shuttle driver stuck
Shuttle driver will not rotate and is stuck on the right side, therefore it won't bring the bobbin thread up. Any idea what's wrong? Can I fix it? Machine hardly used only 3 years old.
bargainbox
  • 1388 Answers
SOURCE: kenmore sewing machine 15008100 not working
Was all well and working before you did work on the bobbin area ?
Ensure the machine is unplugged & bobbin winder is set OFF as there is a clutch preventing the needle arm to operate when bobbin winding......remove the needle.
If you take the bobbin and hook out, can you manually rotate the handwheel forwards ?
If yes, this suggests they are not inserted quite right, or the timing is out of adjustment.
Can you rotate the handwheel backwards ? On some machines the clutch allows for reverse travel freely, but only around the 15 degrees you mention forward when the top cover is off.....there may be a broken or dislodged spring unit/armature inside top near the handwheel and bobbin winder assembly that is acting as though the top cover is open (a safety feature)....generally towards the rear of machine and acting like a log thrown into a gear.
This may help straight away, or only just start to unravell the cause....
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 4 Answers
SOURCE: Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
  • 10865 Answers
SOURCE: need online manual
go to this wevsite and you can download the manual you need for a very nominal fee:
http://www.mastersewusa.com/?OVRAW=sewing%20machine%20manuals&OVKEY=sewing%20machine%20manual&OVMTC=standard&OVADID=7478973521&OVKWID=58585945521
Posted on Feb 11, 2009
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
My shuttle came out and dont know how to put it back.
Hold the bobbin case with open side towards you. The thread should unwind on the top of the bobbin from the left. Place it in the case so when the thread is pulled into the slot in the side, the bobbin rotates clockwise. Pull thread to the left under the tension spring and fit case and bobbin over the central spool inside hook assembly. With the locating finger in its recess, press case home and it will lock into position with a click..
Apr 02, 2014 | Brother LS-1520 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN ON THE BROTHER VX-1250!
Hello
Place a spool of thread over the spool pin, which is a vertical spoke located at the back-right of the top of the sewing machine.
Take the end of the thread from the spool and carry it left along the top of the machine and around the bobbin winding tension disc, which resembles a small button.
Pass the end of the thread through the small hole in the side of an empty bobbin, threading from the inside. Push the bobbin down onto the bobbin winding shaft, which is a small metal spoke at the front-right of the top of the sewing machine.
Click the bobbin over to the right, then manually twist it in a clockwise direction until you hear the spring on the bobbin shaft click into place.
While pinching the end of the thread that is coming out of the hole in the side of the bobbin, slowly press your foot down on the foot controller so that the thread from the spool winds around the bobbin. Let go of the thread end and continue pressing until the machine stops automatically, which means the bobbin is full, or when the bobbin has as much thread as you need for your project.
Cut the thread connecting the bobbin and the spool, and trim the thread end coming out of the hole in the side of the bobbin. Click the bobbin over to the left and remove it from the bobbin shaft.
The Lower Thread;
Turn the balance wheel (the disc at the top of the right side of the sewing machine) toward you to raise the needle to its highest point. Lift the presser foot with the lever located behind the needle shaft. Remove the extension table, if it is attached.
Open the shuttle cover, a small door located on the front of the sewing machine, underneath the needle. Remove the bobbin case, which you see held in the center of the shuttle race, by pulling the hinged latch on the front of it.
Pull about 4 inches of thread from the bobbin and press the bobbin into the bobbin case so that it will turn clockwise when you pull on the thread end. Slide the thread into the slot on the side of the bobbin case, over the tiny tension spring and into the delivery eye.
Hold the bobbin case by its latch so that the metal finger is pointing upward. Press the bobbin case -- with the bobbin inside -- into the shuttle race. The metal finger should fit into a vertical notch at the top of the shuttle race, and the bobbin case should be held securely in place.
Close the shuttle cover.
The Upper Thread;
Rotate the balance wheel toward you until you see the take-up lever raised to its highest position. The take-up lever has a metal loop at the end of a narrow spoke, and it will emerge from the top of the thread guide, the vertical **** at the front of the machine above the needle.
Take the end of the thread from the spool and take it left along the top of the sewing machine, around the rear thread guide, then toward yourself and around the front thread guide.
Take the thread down the front of the machine and from right to left around the tension control dial, which is the round knob to the right of the needle. Pull the end of the thread so that the part that passes around the tension control dial is taut and flush with the front of the machine. You should feel the thread slip between the two tension discs.
Carry the end of the thread upward from the tension control dial and through the eyelet at the end of the take-up lever. Bring the thread downward and hook it behind the thread guide, which is a small wire loop at the top of the needle. Insert the thread end through the eye of the needle from front to bac
Pull a tail of about 4 inches through the needle and pinch the end of it with your left fingers. Turn the balance wheel toward you with your right hand until you see the needle lower through the needle plate then rise back up again. You should see the lower thread looped around the upper thread. Untangle it and pull both thread ends until they have approximately 6-inch long tails.
If you have lost the original instruction manual that came with your Brother sewing machine, you can download one for free at the Brother website.
Jul 12, 2011 | Brother XL-5130 Mechanical Sewing Machine
My kenmore is about 30yrs old .Never had a problem till now. I was sewing and stitched over a pin, broke needle,replaced needle. Now the problem is that the top thread bunches up underneath,also after i...
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Feb 22, 2011 | Kenmore Sewing Machines
Older 830 will not zig zag stitch. leavers and gears move fine. The needle moves back and forth - left and right but it doesn't pick up thread from the bobbin on the left side so it does a strait stitch...
Firstly, make sure you have fitted a new needle and that you have cleaned/oiled the hook race. Unfortunately, if you are finding that the machine will pick-up the thread and stitch OK when the needle is one side of the stitch-plate, but not when its on the other, it suggests that the timing/synchronisation is out and will need to be professionally adjusted. You can check the timing by adjusting the needle to its right-most position, remove the bobbin case, rotate the handwheel until the needle has gone down through the stitch-plate and is just about to come up again. Stop there. Tip the machine slightly back and release the black plastic hook/shuttle retainer by pressing the metal lever on the top-left side of the bobbin door, so that the hook/shuttle retainer pops open. Drop the hook/shuttle retainer, but leave the hook in place ... be careful that it doesn't drop out and slowly rotate the handwheel until the pointed part of the hook/shuttle rotates clockwise to the place where its point is directly behind the needle. Look carefully and you should see that the point of the hook/shuttle is just above the top of the thread hole in the needle. If it's much lower or higher, the timing is out and will need to be adjusted.
Feb 06, 2011 | Bernina Activa 130
Consew226 needle not picking up bobbin thread
I would just send it to a mechanic.
Aug 03, 2010 | Consew 226R-1
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
How do you get the bobbin in
right below where the needle goes into the bottom housing there is a door. open up the door and right under the plate is an opening that revolves. the bobbin goes into this opening. when you put the bobbin in here bring the tail of the thread out of the opening. the shuttle that carries the bobbin will rotate and get hitched to the needle's thread and form the lock stitch of the machine.
Oct 20, 2009 | White Sewing Mighty Mender WW100...
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
I have a 15212 model sewing machine & have hardly used it. When sewing the other day a few stitches went out of the fabric and got stuck. I opened the shuttle assembly, cleared the tangled thread and...
Sorry to say but one of your steps is incorrect. Look at it again, take a deep breath and gom
over everything slooowly. If this really doesn't work then Im afraid it's a technician you need :) .
Apr 27, 2017 | Kenmore 15202 Mechanical Sewing Machine
Kenmore 15202 Mechanical Sewing Machine Logo
156 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
