Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool ET1CHMXKQ03 The Ice maker just stopped working. Any ideas on what the problem might be?
  • luv2snggle Oct 19, 2008
    Ok, well it just filled up with water on its own, and we will wait to see if it produces ice this time. Thanks
  • 958 Answers
Check first if there is water coming in the ice maker.
check the water solenoid at the back of the fridge. check the water line if there is water coming to the solenoid.
if you have filters installed, check the water coming out of the filter. it could be clogged.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • francis rivero Oct 19, 2008
    as long as the refrigerator is cooling very well, it will make ice. check the freezer section, check the temperature. if it won't go down below 15 F. then the problem could be in the freezer section temperature and not the ice maker.
    tnx for the rating,
    drcool
Hello I have a whirlpool side by side model # ed5jhaxml00. The ice maker stopped working, I still have water in the door. I replaced filter and is still not working. Any Ideas?
American Appliance
Hard to know exactly without being there on the spot but the link will provide good information on how they work. Your fridge also has a dual water inlet valve. The door can provide you water while the ice maker can not receive water because of the second inlet valve.
Whirlpool W10408179 Water Inlet Valve AppliancePartsPros com
Jan 15, 2015 | Whirlpool Refrigerators
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
How can i check to see if the defrost is working in my whirlpool refrigerator model number ET1CHMXKQ03. Initially water started leaking into the fridge from the freezer, i looked and saw everything iced...
you will need to access the heater in the rear area of the freezer compartment and disconnect the heater element and take a continuity test of the element,if this checks good,then in the same area is your defrost timer,unplug the heater from it and hook up a voltmeter and energize the defrost timer manually and see if you have a voltage there
Jan 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker quit making ice; water works
is there ice in the maker but will not droup out?
Jul 23, 2009 | Whirlpool GS6NBEXR Side by Side...
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Temperature control
hiya
the thermostat should be inside the fridge compartment usually near the light.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ice maker not turning the ice out
most likely the icemaker module has a broken gear. very easy repair. purchase whirlpool part# 8201515 and replace the motor module on the front of the ice maker.
Oct 28, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool side by side icemaker won't stop... lol
no you shouldnt have to replace the ice maker, the stop arm probably is not in place. pull the ice maker out and check where the arm goes into the motor head. I think that will solve it for you. Good Luck.
Sep 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
415 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
