Question about U-Line Icemaker
U-Line BI-45A won't run
My BI-45A was running but not making ice. I discovered that the fan motor was running very slow so I replaced it. Now neither the compressor nor the fan run. I know that I have power to the unit because when I manually advance the ejector, it completes the cycle - including adding water - but the compressor and the fan never start up. Is there something I need to reset ? Is there some other part than I need to replace ?
Thank you. shopper5@mindspring.com
  • shopper5 Oct 19, 2008
    Thanks, drcool299. I could not find any loose or disconnected wires. I used my ohmmeter to check the thermostat and it showed an open circuit across the two two terminals that have wires connected to them - regardless of the position I put the thermostat control in. So that looks like it might be the problem. I am confused, however, that it should go out right at the time that I replaced the fan motor. That seems too weird to be a coincidence. Any thoughts as to how this could have happened ? I would like to have some more assurance before I shell out the money for this additional part. I did some checking on-line and it looks like a thermostat for the BI-45A will run me 45-50 USD. Any further thoughts you might have would sure be appreciated. Thank you. shopper5@mindspring.com
    drcool299: Well, your very first suggestion to me was right on target. In the process of checking the status of the thermostat and the new fan motor, I discovered that a connection to the thermostat had come loose - most likely while I was removing the old fan motor. This connection powers the compressor and the fan. I put it back on and both of those components now work. That is the good news,
    The bad news is that I am back where I started - except with a new fan (motor and blades). The fan and the compressor run, but the system does not cycle and it does not cool. What advise do you have for me now ? Thanks, shopper5@mindspring.com
  • 958 Answers
Check the wiring diagram at the back panel. trace each component.
you could have disconnected one or two wires while replacing the fan, check the thermostat control. see if there is continuity. check the wirings also that went there.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • francis rivero Oct 19, 2008
    unless you put a shorted fan motor. that could break the contacts of the thermostat.
    try to jump first the thermostat leads just to be sure that there is no shorted part that would ruin a new thermostat. check if everything would run ok and seeif it would freeze and make some ice.
    if everything works fine, then replace the thermostat.
    tnx again, please don't forget to rate me.
    drcool
  • francis rivero Oct 20, 2008
    i don'r know if you have a gauge manifold. the tool that can measure the pressure of the system,
    i would like you to measure the amount of refrigerant in the system while running.
    you could have a leak and the gas leaked out and there is no DIY in case of refrigerant leak
    try to look all over the lines, evaporator, condenser, any refrigerant line and look for oil stain. that would be your leak.
    you have to bring it to a tech for repair.
    hey, tnx 4 the rating. i appreciate it.
    drcool
Why doesn't it freeze or make ice?
The freezer fan motor is running slow, replace this part, this is a common fault
Ian
Aug 14, 2015 | Daewoo Refrigerators
Fan on freezer won't com on but freezes food on
Hi and welcome to FixYa, I am Kelly.
There are 12 midelos that fall under the model number you passed. I will cite EV171NYMQ05 as a reference model number via this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769
The freezer fan should be on anytime the compressor is on. If there is an ice block built up on the evaporator coils it can lock the fan blade in place via the ice build up. Additionally... if the fan motor bearings are dry or coated with sludge this too can prevent the fan motor from operating. The fan motor is item 3 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28174432#d28174432
Detail views:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-motor-evap-item-number-ap4539455.aspx
To check the can motor all that is required is a simple continuity check across the 2 connector wires. You should read under 480 ohms.
If you discover that the fan blades are encased in ice... do a manual defrost: (be ready to tend to a water mess)
1. By first unplugging the unit and then removing the freezer contents.
2. Direct an external fan into the freezer compartment for just over 2 hours.
3. Make sure the compartement drain funnel is clear of obstructions. Item 11 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28158051#d28158051
After the 2 hour manual defrost period plug in the unit and test to see if the fan motor is running.
If it is running you may have an automatic defrost problem causing the ice build up. On a freezer the ice build up will start again if there is an automatic defrost problem in 3 - 5 days. Until the automatic defrost problem is corrected you will end up doing the manual defrost routine described above everytime you have improper cooling problems.
Components that can cause the automatic defrosting problems are
1. The defrost timer item 7 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28257341#d28257341 Because it is not cycling or stuck in one position.
2. The defrost bi-metal thermostat item 9 above link (stuck closed)
3. The defrost heating element item 5 above link. (open)
And of course internal wiring....
Check the fan motor for continuity... if you attempt to lubricate it which is very difficult on this fan motor make sure you use paraffin based "Turbine oil" and not a regular household or automotive oil. Using any other oil will cause the fan to stop working in as little as 30 days.
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
Freezer doesn't seem cold enough, took over 24 hours to make ice cubes!!! Small fan at the back of the freezer doesn't seem to work regularly, fridge seems ok
If the fan in the refrigerator (evaporator fan) isn't working properly your machine isn't going to be as cold as it should be and your ice maker won't work properly as well. This is due to the fact that the ice maker has a sensor in it and it won't produce ice unless the sensor tells it is lower than 10 degrees F. A rule of thumb is if the condensor fan motor is running, which is the fan located by the compressor, than the evaporator fan should be running as well. Now, with that said, there evap fan is tied into what they call a bi-metal thermostat. Depending on the brand these sometimes go bad causing the fan not to run, but that wil cause it not to work at all. If its working intermitantly, than chances are the fan motor is bad.
Nov 08, 2010 | Refrigerators
My u line under counter ice maker (bin, not clear ice) will take forever to make ice. Once it starts to make ice and drop it in the bin, several hours later it will stop making ice and the made ice will...
Can you tell me the model? If its a bi series then it should make ice every 45 min. temps should be 10-15 degrees in bucket. If its a combo then it could take 24 hours to make 1/2 of the bucket.Should be the same temp in your bucket.Make sure you dont have heavy frost in the freezer, Make sure the condenser fan is running and clean.If the temperature in freezer is alot warmer than this and everythng is running then it could be a leak in the system. If its colder than that then set the thermostat to a warmer temperature
Aug 06, 2009 | U-Line Icemaker
I have a u-line bi-95 ice maker.the machine will only drop ice once after it is turned on. i also notice it gets very hot near the vent.the machine does get cold enough inside to keep the ice.what should i...
Your unit will only harvest when your thermostat is satisfied. If you have heavy frost you need to defrost the unit. If no frost then make sure the fan is running by the compressor. If the fan isnt running then the compressor is going off on overload. Or it could be the fan running but the compressor is not. If thats the case you will need a service tech.
Aug 03, 2009 | U-Line Icemaker
Our old RV U-Line Icemaker, model 45A has stopped making ice and does not get cold. What does it need?
You need to check to see if the compressor is running and the fan is running. If both are then you need a new unit. The 45A has the r12 refrigerant in it and you wont be able to get parts for a r12 system. U-line makes a BI95 to replace that model. If the fan isnt running then I would replace the fan. If nothing is running then it could be a bad thermostat but first make sure the ejector blade on the icemaker is at the 12 oclock position.
Jul 17, 2009 | U-Line Icemaker
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Jul 04, 2009 | U-Line Icemaker
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Jun 30, 2009 | U-Line BI-95
U-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
May 24, 2008 | U-Line Icemaker
U-Line Icemaker Logo
438 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
