Question about LG 42LC2D 42 in. LCD HDTV
No sound for my ps3
I have bought a hdmi cable for my ps3 and a dvi adaptor for my tv, when i connect it up the picture is fine but i have no sound through the hdmi channel ? so i connected the rca at the same time and have sound on my av1 channel but no picture , the picture is on the hdmi channel, how do i get the sound to play through this channel ?
    Champion:
  • 211 Answers
There's a set-up menu in your ps-3, you have to change the menu from analog to digital output.
Kind regards, Gerard
Posted on Oct 23, 2008
  • Kayla Atwell
    Kayla Atwell Jul 28, 2016
    I've been trying to figure why I didn't have sound for 3 days. Thank you so much this worked!!
2 Suggested Answers
SOURCE: no sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
Oct 19, 2008 | Televison & Video
Ps3a
I have had this problem once before and it was because my sound output was was set to the (yellow white red) and so what you have to do is go to Sound Settings then go to Audio Output Settings then what your going to choose is HDMI then it will ask for what method and just select Automatic, then you should be able to here sound threw your tv.
Oct 13, 2008 | Sony Playstation 3 (PS3) Console
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Hdmi to dvi
a DVI Connection does not transmit sound, so you will need a seperate audio cable. Have you changed the settings in the ps3 and your tv's input to HD signal or 720 DPI, do not choose 1080i or 1080P as DVI does not support those high settings.
Sep 05, 2007 | Sony Playstation 3 (PS3) Console
LG 42LC2D 42 in. LCD HDTV Logo
134 people viewed this question
Computer Repairing
Computer Repairing
