TV Issue Still
Thanks for your responce yesterday,l tried to let you know that l use no cable box,cable comes straight from street to back of my TV,
  • sam221 Oct 19, 2008
    TV repair came and took the TV today,,thank you anyway
As l said yesterday,the repair man has taken the Tv to try to solve the problem,,,thanks anyway.
Posted on Oct 20, 2008
  • 1,183 Answers
Hi Sam,
I was researching on the problem, and have quick question to ask , have tried putting the system in auto tunning mode ? To retune the channels.
If retuning doesnot do the job, the system would have to be taken in for repairs as the Tuner card inside the TV would have to either serviced or replaced
Thanks
Proton
Posted on Oct 19, 2008
  • Mandeep  Singh
    Mandeep Singh Oct 20, 2008
    Hi Sam,
    Kindly do lemme know , what you got replaced on the unit or what was repaired . Its was a unique problem.
    Thanks
    proton
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Never had an issue until yesterday... When I turn the tv on,it immediately begins scrolling through all the channels and won't stop. It will not respond to the
I will assume you tried to unplug the set and plug it back in.
If you are using a sat or cable box connected to the cable fitting on the set try connection from the AV jacks to one of the video inputs on the set.
If set does it via the rear jacks it is likely the box and not the set.
Mar 15, 2012 | Samsung HL-T6187S Television
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
xtreamz_69,
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
Tv size keep changing
Thanks for coming to Fixya with your issue.
Allow me to try and understand your issue fully does the TV change size when you switch to a HD channel?
What happens is if a channel reception is interfered with, or the signal is too low to produce a HD channel you size will go from HD to standard DEFinition.
Now if the signal is good ether from the cable box or from the antenna then we are talking a decoder issue. So I need to know as far as clarification goes.
1. When does this happen
2. Does it happen on all channels
Thanks for your questions please do update me with more information so I can get back to you with a positive in depth answer.
Thanks for using Fixya.com
Nov 18, 2010 | Samsung LN46C550 TV
The picture will not come in or if it does it is all scrambled when hooked up through digital cable box
Try disconnecting the cable box and run straight cable from the wall to the tv. If it clears up it is the box. If it does not it is probably a horizontal or power supply problem inside the set. Hard to say without actually seeing the set. Thanks for using fixya.
Nov 10, 2009 | Toshiba CN36V51 TV
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Panasonic PT-50DL54 50 in. Color spectrum off
Yes, I have a cable box, and I do get high def channels.
Jul 09, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
