Question about Hitachi CMP4121HDU 42 in. Plasma Television
3 Inch block on right side top to bottom.
My plasma was dropped and from then on there has been a 3 inch block top to bottom on the right hand side. The TV still works fine on the rest of the screen, it's just that section where all there is this block of coloured lines which some times go white. It looks like there are lots of thin lines up and down. If worst comes to worst I will just have to watch on reduced size.
  • alligator58 Feb 22, 2008
    I HAVE THE SAME PROBLEM ON MY PANASONIC PLASMA THAT HAS NEVER BEEN DROPPED AND WHEN IT GOES TO THE REPAIR SHOP IT CLEARS
    PLEASE HELP
  • thugboy40000 Feb 18, 2009
    scren block
    President:
  • 3,130 Answers
I agree 100% as it sounds like you broke the display on the set and boy oh boy is that expensiver to replace. Hopefully you have a warrantee and dont mention you dropped it. Good luck
Posted on Jun 14, 2006
  • 53 Answers
Your best bet is to call hitachi do not mention unit being dropped raise all kind's of hell and hope for the best.
SOURCE:
Hello , my name mike I Have a samsumg 42 inch plasma model pn42A450p1d . Picture looks good other than left side has a 3 inch black section from top to bottom. Any help
Hi, My name is Amp:
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 20, 2016 | Samsung PN42A450 Plasma TV
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Leaking from bottom middle and right side of door
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
May 11, 2010 | Frigidaire PLD2855RFC Dishwasher
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Red screen
Call Associated Electronics with your model number and product code, and tell them your problem. They will be able to help you out. You need to replace a pcb.
Mar 23, 2009 | Samsung PN42A450 Plasma TV
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
Hitachi CMP4121HDU 42 in. Plasma Television Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
