Question about GE Refrigerators
Small fridge shut's off won't start back up unless i turn the switch off and wait a few seconds then turn it back on then it will run till it shuts off again
  • 958 Answers
I am assuming the switch you are referring to is the thermostat.
unplug the unit.
get a lubricant of WD-40, spray it inside the thermostat to lubricate the mechanical parts inside which is getting sticky.
then test it again. if it won't fix the problem, then replace the thermostat.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
I have a 1987 Plymouth Voyager that starts, fuel pump comes on but it just runs a few seconds and stops. If you turn the key off and back on, the fuel pump comes back on but shuts back off in a few se
On the fuel rail will be a small round valve type thing with a rubber vacumn tube running to it ,check the tube and make sure its connected as this will stop it from running as it opens the fuel rail for the injectors
Jan 03, 2013 | Cars & Trucks
1994 ford ranger runs fine until i go to town then just shuts down but will crank over and fuel is getting to it
check ignition pick up its in the distributor. its responsible for spark in the plugs
Dec 04, 2012 | 1988 Ford Ranger
Pool heater kicks on and off
safety switch is opening and closing, or issue with gas valve coils
Sep 17, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
What are the dimensions for roper refrigerator rt18dkxfw01
The problem is a no defrost.Open the fridge door and look at the control box where the thermostat is located.Look from the underside of the box you will see two small screws and a small hole , Use a flat screwdriver and turn the small cog on the defrost timer till the fridge shuts off.Wait 15 min and tell me if the coils start to thaw
Custom Headlights For Audi
Jun 11, 2012 | Roper RT21AKXKQ Top Freezer Refrigerator
My husqvarna 61 inch lawn mower will not stay running
Did you check the oil? Some engines have a low oil shut off switch to prevent the engine from running out of oil and burning themselves up. If it is low in oil and all the oil is up in the engine to lubricate, then the switch may be setting itself off. After a few minutes, the oil comes back down to satisfy the switch and it starts back up, but only till the switch is activated again. Might do it???
Dec 27, 2011 | Husqvarna Garden
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
Aug 22, 2011 | 2005 Ford Expedition
Engine starts fine, runs fine for about 5-10 minutes of various speeds. Then it shuts down suddenly regardless what trottle possision. Engine will start right away again, but promblem will accure after few...
Could be so many things, I know on modern Harleys there is a shut off relay that turns off the engine if the bike is on its side. If that switch goes out, the motor won't run. Probably have to take it to the dealer.
Jul 08, 2011 | Honda Fusion Motorcycles
My furnace stopped working. It'd start up shut down start up shut down all in the matter of seconds. Then would fire up and work. it did this maybe once every couple days then it stopped all together. ...
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Mar 04, 2011 | Goodman GMS90703BXA Heater
Turns on hear a click shuts off
Bad thermostat is the most lilky cause,
Jun 20, 2010 | Haier Water Dispenser w Fridge...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
KJ4QOB
Da Doc
jerry earick
