Epic Z - Water coming out the front soap tray
We have had the laundry room soaked with water three times recently and finally tracked down the problem to water coming out the front of the push in soap tray. We witnessed it happening today (during the initial filling) and pushed the tray back in, which stopped it.
To our dismay, it must have leaked again during the rinse cycle, because the floor was soaked.
Has anybody else had this happen? We are contacting Maytag for help.
  • Anonymous Jan 23, 2009
    Not only tray, but pipe to drum clogged. I am going to try washing soda to dissolve the gung that I cannot reach.
  • 958 Answers
You can try pulling the soap tray out and clean all the old detergent and softener in there. they do clogged the outlet of water for the water to overflow.
check also where the soap box is inserted. it would also have lots of dirt.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
Soap dispenser overflowing with water
You will have to pull the dispenser tray out and clear any debris. I've seen a sock in one (who knows how that got there,) toys and even a glob of laundry detergent pods leavings.
Dec 21, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water leaks from my detergent dispenser from my front loader washing machine?
This is usually indicative of soemthing blocking the flow of water out of the soap tray, down the connecting pipe and in to the drum chamber.
The soap tray doesnt have any seals as water should just flow into the tray, wash out the soap / fabric softner, and then flow out the back of the tray and down the connecting pipe. When working correctly, there is no pressure or water back-up to cause the water to reach the front of the soap tray.
Take out the tray - your machine user manual will show you how, and check both the tray itself and the "hole" it slots in to for either a build up of solidified soap powder, or some other foreign object. If still leaking, remove the tray again and try to get your hand (a woman's or teenager's hand being smaller is best) down the large oulet at the back of the "hole" the tray slots in to to feel for a blockage.
Do you have young children ? A washing machine soap tray is a great place to hide things !
Occasionally, if the smaller pipes that deliver hot and cold water to the tray come adrift, this can spray water at the front of the machine. This water then has only one real way out - via the soap tray "hole". Most often this will be the cold water pipe as this has higher water pressure to cope with. The only way to check this is to take the top of the machine off.
If after all of the above it still leaks, you'll either need to dismantle the machine enough to see the back of the soap tray "hole", connecting pipe and drum chamber for a better look for problems, or call an engineer.
Nov 04, 2009 | Maytag Washing Machines
The machine is leaking water from the soap tray how do i stop this?
Do have young children ? A washing machine soap tray is a great place to hide things !
Sep 30, 2009 | Zanussi FJS1225W Front Load Washer
Water leaks from softner dispenser
I had same thing with MtgNeptune frnt loader. Manual sed may be a kink in the front drain hose, caused by sudden burst in water pressure. Not in my case. A service call and $90 laterwasn't fixed. I pulled the soap tray and found rinse water wasn't going down the well as fast as it was filling, causing water to spill down front, and around the door. I turned down the water pressure 2 days ago and 9 loads later- no problem! It may take a few minutes longer to fill, but far less work than mopping after each load or hitting 'pause' and 'start' while waiting for the the water level to go down. We're on a well and ocassionally have change in water pressure. I don't know if this was the problem, but it was definately my solution! I turned the intake vavles at the wall to 1/2 pressure. Floor is staying dry and the drain tray beneath is also dry ($12.00 Menards). I hope this helps.
Jan 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag Neptune washer #MAH550Bww Serial #88922156AJ has water coming out the front door and getting my laundry room floor wet. I have also noticed a musky smell in some of my clothes just after washing
You need part 12001772. The issue with the smell is a combo water, too much soap and too long of a cycle. 2 Tbl of soap and a lighter cycle is usually fine for these machines, plus to keep the soap drawer clean:) Here is a pick of what you need. See part 18
Oct 12, 2008 | Washing Machines
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Leaking...
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
Sep 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
