Question about Toshiba TP55G90 55" Rear Projection Television
Power light is blinking TV does not turn on
Toshiba TP55G90 9 yrs old. Noticed the power light (LED) was blinking, never saw that before, and it will not turn on. I have unpugged overnight and still doing same thing. Thanks.
  • Alan2515 Nov 13, 2007
    Any good, reasonably priced professionals in South Florida area that can fix this problem?
  • Anonymous Nov 26, 2007
    Have the exact issue ! Power light Blinking worked fine thru the weekend dead at 1am sound no pic..... this am no sound and no pick.
    Mid Michigan area, needing a repair guy !
    President:
  • 3,130 Answers
Mosy likly the regulator Ic in the main power supply . Not a consumer replaceable item because of xray and safty issues Call in a shop to assit you in this matter. Good luck
Posted on Jun 14, 2006
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
I have a 6 yr old toshiba 50hp16 that is currently not working. I was watching the tv last night...heard a pop...and noticed the picture got darker and the pixilation got very grainy. The television...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 11, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
May 03, 2010 | Toshiba TZ43V61 43" Rear Projection...
Hi, We have a Toshiba rear projection tv model 46WH08G which wont turn on. by this we mean that the red power led light is on and weve noticed that the green led light alongside is flashing, which has a...
It sounds you need a new Projection Lamp; they usually last for 2000 hours or more. The led blinking is the lamp warm-up period and it fails now, if you replace the lamp be careful very static sensitive and blow the dust out with air while the TV is open. Hope this Helps.
Apr 08, 2010 | Televison & Video
Can not turn TV on
Failing power supply. It's 14 years old.
Feb 19, 2018 | Toshiba MD14F51 14 in. TV/DVD Combo
the power is blinking because there is a deffective parts... the supply that makes oscillation of tv has been cut off... either the horizontal transistor is open or the resistor from the abl change its value...if you have knowledge with the parts maybe you can try... only the qualified servicemen can repair the problems...
Aug 29, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Kids.
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Nov 23, 2007 | Toshiba 32A42 32" TV
SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
I have a SONY WEGA 3 years old KV-32XL90E and have the same problem the Stand By/Timer light blinks 16 TIMES, pauses and then does it again.The sound is but no picture.
Nov 13, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
73" rear projection Mitsubishi TV
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Sep 05, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Flashing Power Light
Toshiba rear projection with blinking LED =
1) Open micro fuse F850,851,etc....caused by
2) Bad solder connects....jumper wires 008,010,017,048,600
re-solder all and solder STK392-110 convergence amp pins.
3) Or consider replacing original IC's with improved version...
STK394-160 = Hitachi part # CZ 01341
.........................T.
Aug 30, 2006 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
303 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
