Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop vac 90L400 stopped working won't start
I have a shop vac that I was using and it just stopped. It is a 90L400 I can't find my manual so can you please advise & let me know where I can view a manual for troubleshooting. Your site prompted me to put the wrong type of shop vac. The model # is as listed in this e-mail.
    Problem Solver:
  • 7 Answers
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Posted on Sep 28, 2009
  • psc777 Oct 17, 2010
    This is exactly what I just got done doing to mine. Works like a champ, Thanks! I thought I would never get to the "fuse". Take some torx off, take a cover off, more screws, repeat a few times, lol. I use mine for vacuuming out the car only, so it is never on very long. Just disappointed it died with so little use, and never on very long. it practically looks new, heck the bag in maybe 5% filled up. But it is about 5 years old.
    MY REPLY GOT POSTED BELOW ON 2rickie's POST, please ignore
  • Anonymous Mar 20, 2017
    I just did the same fix, but I discovered the root cause: the intake filter was clogged and undoubtedly was causing the motor to run hot. I happened to have 14 gauge solder and inserted that into the thermal fuse housing, so I think that's a better fix if you want to preserve the thermal protection.
It sounds like the power unit has gone bad. I had the same thing happen and called Shop Vac (570) 326-3557. Since it was still under the 3 year warranty, they sent a replacement unit.
Posted on Jan 05, 2009
Sounds like it might be the switch that has went bad. I was able to find the part at https://www.mouser.com. The part is made by CW part number GRS-4021. The cost $3.25 US. This would be a cheaper alternative then buy the whole power unit which would cost as much as the Shop Vac cost new. Does require a little know how or common sense and does not feel leary about disassembly a electrical device.
Posted on Sep 15, 2009
    PLEASE IGNORE MY REPLY. was meant to reply to fmfmedic's post
VERY Helpful Customer service, immediate solution was to send a new power unit no cost to me! Thank you Shop Vac!
Posted on Dec 17, 2009
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Old red and black Genie Shop Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=659916
Posted by girl power on Jun 10, 2008
A Wheel or disk has come off of the motor. I would like to get a copy of the user manual to see if I can determine where it came off of. This Genie Shop Vac was given to us from my father-in-law.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check with the manufacturer Shop Vac to get an owner’s manual for the older Genie Shop Vac would be @ the Shop Vac Website and or Customer Service of which I will give you @ the bottom of the response. Other wise check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
2323 Reach Road
P.O. Box 3307
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
User's Manual
if you go to www.bissell.com you can get one there
Dec 15, 2007 | Vacuums
Shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
Aug 29, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
7,217 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
