Question about JVC AV-20FD24 20 in. TV/DVD Combo
No power my tv won't turn on manually or by remote. I've been using an RCA universal remote since original remote won't work anymore.
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: program my tv combo with my rca universal control
Try following codes for JVC tv/video combo.
012 - 024 - 036 - 037 - 040 - 048 - 051 - 074 - 002 - 014 - 016 - 030 and 046
Hope any of them will work for you.
Thanks.
Posted on May 18, 2010
Orion remote won't turn TV on
You have to setup the DVD by its setup codes with Xfinity. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter" Setup code list, and setup proceedings to Xfinity remote control is given in detail.
Apr 14, 2013 | RCA RCU300WBL Remote Control
Lost the code list for my rcu404N universal remote an trying o program a rca television
Jawanna,
With the information you've provided, I found the following link to the manufacturer's website for the remote. The codes are listed below for a standard RCA television. http://voxrightnow.custhelp.com/app/answers/detail/a_id/8059/~/information,-user-manual,-code-list-and-support-for-the-rcu404n-remote-control RCA .............1547, 1447, 0047, 0090, 0679, 1047, 1147, 1247, 1347, 1781, 1948,1953, 1958, 2002, 2187, 2247 I've included the step by step instructions provided by the manufacturer for programming your remote to operate your TV. If you need other devices programmed, check the link to download the original instructions on your universal remote. Hope this helps.
Feb 22, 2012 | RCA Universal Remote Control
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
I accidentaly turned the FPA lock on my TruFlat RCA tv and the original remote broke. i just bought a RCA universal remote from best buy. now how do i get rid of the lock?
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Aug 24, 2011 | RCA TruFlat 27F520T 27" TV
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
Have an RCA remote i am trying to use with my Vizio 1080p hdtv. Instructions on the universal remote are as follows: -Turn on TV -Press and hold "code search" untill light stays lit. release. -Press TV...
Newer brands of tvs are using new codes that old remotes don't have. Only older learing remotes from original remotes or USB upgradable or newer one that were made after the tv was made will work.
Mar 10, 2010 | RCA Universal Remote Control
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
JVC AV-20FD24 20 in. TV/DVD Combo Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
