Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony trinitron no controller ?'s
How can i adjust the brightness on my tv if i have no controller? is there a botton combo to push or hold on the the tv itself?
    Champion:
  • 252 Answers
There,s some button hiden inside the tc. so ,you need to open it adust the brightness..but ,if your tv is too dark change the resistor value 680K at the CRT board . CRT board is a circuit that attach to the picture tube.
Posted on Oct 19, 2008
Color setting for Sony XBR Trinitron 36" any settings
Hello
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
Oct 26, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture gets bright then blinks black, adjusts and then gets bright and blinks again every 4 seconds. used to be every couple of minutes.
Take the tv aparts.Caution high voltage ERA FBT.The FBT the flyback transformer.That the big block of plastic,with a red wire with a cap hook to the CRT(Tv tube).On FBT that big block of plastic there are 2 knobs one said FOCUS the other said SCREEN.Turn knob said sceen down a bit,will stop get very bright pictures and shutdown,the screen will hold high voltages.
Oct 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron picture bowed
YOU MAY A PINCUSHION PROBLEM...SEE A TECH....CUSTOMER CONTROLS WILL NOT CORRECT THIS !
Dec 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Cant change the bright of the sony trinitron (FROM THE REMOTE )
this is a problem with the sony tv set not your remote.
you can have a tech turn up the HV seting on the botem of your fly back and at same time have him do a diagnostics on the tv set.
Jan 09, 2009 | Sony RM-Y173 Remote Control
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
I cannot adjust the brilliance on my wega trinitron kf32fx60u as it is locked.
Hello Tone66
You can change Brightness, Color * Sharpness settings in Menu.
Push Menu button on remote and go to Picture settings and select Personal/ Custom settings and enjoy.
May 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
