Question about MSI K8MM-V Motherboard
Cannot boot I recently had my box hijacked and finally decided to wipe the drive and start over. I have reconnected everything, but cannot get my system up at all. When I turn it on, I get two beeps and then nothing. I cannot be certain, but it seems like two long beeps with a few second pause in between. I have removed all hardware and booted it in various configurations as well as clearing the cmos. I am at a loss what to do next. Any Ideas?
  • 781 Answers
Check all cables to hard drive CD and floppy are inserted correctly
The stripe on cable goes to the Number one pin on the socket on motherboard andnext to the 4 pin power plug on hard drive and CDon the floppy its the same
Posted on Nov 20, 2008
How do I completely wipe all data on my old Windows XP Machine?
You can use a windows 98 floppy boot disk if you have a floppy driver to wipe out the partitions and format your hard drive.
Mar 03, 2012 | Computers & Internet
I have several hard drives that came out of non working computers,how do prepare these to work in another computer?
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
http://majorgeeks.com/Free_Disk_Wipe_d5309.html
Free Disk Wipe data cleanup and file wipe tool, that allows you to completely wipe/ remove / delete / erase a selected file(s) on most disks (floppy disks, hard disks, logical drives, etc).
Data recovery software can
Jun 25, 2011 | Computers & Internet
I will like to reset my dell inspiron one 2310 to its original factory settings. how can i do that.
You will need a windows CD. It can be what ever windows you would like. I highly recommend Windows 7.
Put this disk into the drive, restart the computer and you must have it boot from the DVD-Drive. You are looking for a boot menu when you computer first starts up. When you finally get it to boot, follow the instructions and you will wat to "format" your drive.
PLEASE NOTE, this will delete everything on your computer and make it like its fresh out of the box. Please backup everything you want to save! This is mostly documents, Music, Pictures, videos, bookmarks, settings etc.
May 19, 2011 | Computers & Internet
I just purchased a Hp notebook dv2214us from an auction but everything was wiped clean off the hard drive due to California Law. I completed a self test off the Bios and everything passed. I just recently...
did you go into the bios and change the boot order to boot to the cd rom first? Then it should boot to the disc. Otherwise you may want to use any xp/vista disc do the install dont insert a cd key then once windows boots up then put the disc in and try a recovery.
Thanks,
Lee
Feb 07, 2011 | HP Pavilion dv2214us Notebook
HP Pavillion m7750n has already had the hard drive replaced almost two years ago. The computer will be four in January. It stopped working about five months ago and I finally decided I had enough time to...
Either the disk is faulty or the the boot block is corrupted. If you have the operating system CD, you can try to reload it. Doing so will wipe out anything you have on the drive. If it reloads, you will be back in business. It the disk is faulty, the OS will not load.
You may want to take this computer into the Big Box store and have it evaluated before youtry to do this repair.
Thanks for your interest in FixYa.com
Nov 23, 2010 | HP Pavilion m7750n PC Desktop
My 1999 Toyota Tacoma recently started being sluggish
what plugs did you use, denso i hope. is the firing order correct?
Mar 06, 2010 | 1999 Toyota Tacoma PreRunner
Error loading operating system
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Jun 28, 2009 | Dell Inspiron 1100 Notebook
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
Hard drive wiped out
may be your hard drive has a bad sector.
Dec 07, 2008 | Computers & Internet
Non responsive program msg on admin.log in or out ,closedown windows,end yahoo email,games,. very very slow computer
Use hijack this.....sounds like you may have a virus or trojan (most likely)....read instructions carefully but feel free to delete (when using HIjack this) anything that looks strange....also I assume you have a good virus checker (Avant or Avg both of are free) and Spybot search and destroy or equivalent.
Nov 17, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
MSI K8MM-V Motherboard Logo
69 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
