Question about Oster 5838 ExpressBake Bread Maker
Bake cycle my dough looks fine and rises perfectly, but during the bake cycle the top caves in. i have checked and double checked and am so careful about the ingredients measured properly and not forgotten, but this continues to happen to various degrees. also the sides are always too dark and hard no matter what crust setting i use. please explain what i am doing wrong or if i need to return it and get a replacement.
  • 3 more comments
  • nomsg Oct 28, 2008
    same problem. The doe does raise but goes down as soon as the bake cycle start
  • amymasson Nov 21, 2008
    Same problem, and I really want some tasty bread that's not too crusty.
  • Anonymous Nov 30, 2008
    Exact same problem.
  • milkncooki3s Jan 21, 2009
    I am getting a hard crust no matter what settings I use. I switched from regular flour to bread machine flour but still have the same problem. Can you offer some help?
  • CmcG2000 Feb 15, 2009
    My last bread machine I only used it to mix the dough and then I baked it in the oven. I bought this one because I wanted horizontal loaves. Well, now I think I give up because ALL OF THE LOAVES SINK!
Return it to the store and get a new one. That's what I did and the new one works fine! I believe it's a defect in the machine.
Posted on Jan 18, 2009
Mixing OK but not heating/baking
That's not a good sign. This will keep your bread from rising properly and baking, obviously.
If you are still under warranty, contact your manufacturer, otherwise, you can still use the machine to mix but you will need to use your oven to finish your bread.
If your bread is not rising in the machine:
  • Remove mxing chamber from machine
  • If the chamber is not removable, UN-PLUG THE BREAD MACHINE so the blades DO NOT TURN.
  • Be careful of the mixing blade in the chamber
  • Remove dough gently with slightly oiled hands into a lightly oiled bowl with room for about 2x the volume of the dough
  • Cover with plastic wrap to prevent the dough from drying
  • Place the bowl of dough in an unheated oven and leave the oven OFF
  • Place an empty lasagna pan in the cold oven on a shelf below the dough or on the floor of the oven if there are no exposed elements
  • Boil some water and pour it carefully into the lasagna pan
  • Close the oven door - You have just made a proofing box. The steam and heat from the boiled water is sufficient to make a great proofing cabinet out of your oven hot box
  • Allow the dough to rise to about twice the original volume
  • remove the dough from the oven and remove the pan of water
  • continue with the baking instructions below
If your bread is rising in the machine or you have finished the above instructions:
  • Remove dough gently with slightly oiled hands into bread pans. Breadmakers are different sizes so you may need to use one or two pans. Or make an artisan style loaf on a cookie sheet lined with parchment.
  • Be careful not to compress your risen dough as this will make the loaves dense
  • You may also choose to make buns by separating the dough into smaller balls and placing on parchment lined cookie sheets
  • You can allow the dough to rise again for a short time in the proofing box above but I would just leave them on the counter under clean towels to prevent drying for say another 20 minutes. Over-rising bread should also be prevented. The result will be 'deflated' looking bread.
  • Preheat your oven to 375F and bake the bread until it is golden and makes a hollow sound when thumped on the top or the bottom crust
Personally, I love that a machine will mix and knead my dough for me while i go do something else but I don't like the appearance of a machine baked bread. I like the artisan hand-made look. I recommend you keep the breadmaker until you find one you like that is drastically reduced in price and just use the artisan proofing & baking options above.
If you have a Pizza Stone, you can also try that for baking an artisan bread. Use the breadmaker as the workhorse, use your oven as an artist.
Good Luck and may the Yeast be Lively!
Apr 02, 2015 | Kitchen Appliances - Others
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Dec 08, 2014 | Kitchen Appliances - Others
Using the same recipe I've used many times, the machine stopped after mixing and before rising, and all lights went off, and did not come back on after a half hour. I am going to start over. However, I am...
If the bread maker still works, means that you had a temporary power outage. You can naturally bake it in the oven, but you will have to allow time for the yeast to activate and rise the dough to approximately double size than the starting dough. You can use a cooking pot full of warm (120-135f) and have the dough seating over it (in the pan that you will bake it in).Cover the whole thing (water and dough)with terry cloth towel for minimum of 45 minutes and bake it in a pre-heated oven (425f). Avoid any drafts durring the rising of the dough.
Jan 16, 2011 | Panasonic Kitchen Appliances - Others
All ingredients are measured exactly as specified. During the rise cycle the dough is practically overflowing. When it starts baking the dough drops with the largest amount in the center of the loaf.
The next time you bake bread use one tablespoon LESS liquid. If it stills falls then the 2nd time use one Tablespoon less liquid AND ONE TABLESPOON MORE FLOUR. That should do it. Please let me know how it works for you.
Dec 05, 2010 | Cuisinart CBK-200 Bread Maker
My ABM 6000 machine was accidentally unplugged near the end of the rise cycle. Can it be set to finish. When I restarted it it began kneading the dough again.
If you feel your dough has risen enough (look at your cycle times and estimate how long it was into the rise) and if so you could set your machine to the "bake" cycle and then click the timer button in 10 min. increments until it is set to bake the right amount of time. Maybe this will work. Hope it does!
Oct 28, 2010 | Welbilt Kitchen Appliances - Others
Bread is falling during baking
I had this same problem. It has to do with the amount of water and the amount of yeast you are using. I decreased my amount of water to 1 cup ( of course it depends on your recipe) and I also was using rapid rise yeast which calls for a less amount (usually 1/2 tsp less than what the recipe calls for). I did experiment with the recipe until I got it just right. Good luck. Carrie
Jan 16, 2009 | Welbilt ABM3500 Bread Maker
Bread Rises Beautifully - then sinks in middle during bake cycle
Sinking in the middle means that there was too much rising for the amount of structure in the bread.
Usual causes:
-too much yeast (reduce 1/2 tsp.)
-too much sugar (reduce 1/2 tsp.)
-not enough salt (increase 1/4 tsp.)
-too much water (reduce 1 tbsp)
Another possible remedy: use "best for bread" flour, it has more gluten, or add gluten separately, 1 tbsp.
Start with reducing amount of water.
Jan 04, 2009 | Breadman TR520 Bread Maker
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Kneading blade keeps baking into the bread- help!
Watch/listen to the machine your machine. After the last knead cycle, remove the paddle from the bake pan before the dough rises, continue to bake as normal.
Dec 05, 2008 | Sunbeam 5891 Bread Maker
Collapsed bread
Likely, your loaf is too wet.
This can happen with as little as 1 Tablespoon too much liquid. It's hard to describe "the look," but what I learned to do was to watch the bread during the initial mixing cycle (after the paddle begins to turn full circles). The dough should not stick to the side of the pan while mixing, and it should look elastic, but not shiny. If it looks shiny, there's too much liquid in relationship to flour. I add a tablespoon of flour at a time during the mixing cycle, until I get a good consistency.
There's nothing wrong with the taste of the sunken loaves. We usually just shrug and eat them anyway.
Mar 29, 2008 | Sunbeam 5891 Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
150 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
