Question about Philips GoGear HDD060 MP3 Player
Philips Gogear - please help!
Hi there I purchased the product 6 months ago second hand. Now when I try and charge the item throught the mains or usb the blank screen just flickers and the item doesnt power on, ive left it on charge like this for hours but to no avail - please help!
  • 175 Answers
Check that battery still has the original voltage if not you need to b=get it back to it.
Posted on Jun 26, 2006
SOURCE:
Power problem.
just get a small screwdriver and take off the back..look on the right side and you should see how the slider works..after that its easy to fix..i hope this helps.(:
Jul 15, 2010 | Philips GoGear ViBE Digital Media Player
Format problem
se travo al borrar 2 imajenes
May 17, 2009 | Philips GOGEAR SA6045 MP3 Player
I have a Philips Gogear Mp3 player. suddenly I'm not able to switch on the power supply and i tried charging it for 4-5 hrs.no Use. It's just 4 months old. can u help me?
It's dead. The HDD models are basically obsolete - you may have purchased it 4 months ago, but it was manufactured 3 years ago. Here is the basic troubleshooting to be sure, but it won't work:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD1830 MP3 Player
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips HDD082 MP3 Player
Philips gogear sa261 doesn't switch on...
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips GoGear SA261 MP3 Player
PHILIPS GOGEAR 6GB
The same thing happened to me. I contacted Philips and they sent me this solution, which worked for me. Question My GoGear has no power/no display even connected to the power supply with the AC adapter. What should I do? Answer Do a soft reset by pressing and holding the Power On/OFF button and the volume + key for a couple of seconds. Then connect your GoGear to a power outlet with the AC Adapter to charge the player again for around 30 minutes. Try turning the unit back on and see if the display appears. If the display is able to come on again, keep the player connected for another 3-4 hours until it is fully charged before use, else contact our Customer Care Center for assistance.
Jul 12, 2006 | Philips HDD1630 MP3 Player
Philips GoGear HDD060 MP3 Player Logo
90 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
