Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Brand new gas range
Connected it up, turned on the shut off valve per instructions, burners all work well, no broiler or oven gas lights, ignitors glow bright. Not rocket science, push bake, set terperature for oven, push broil, push hi or low, whats up ?
  • shooter_9mm Oct 20, 2008
    Dead on, actually I found it out accidently, I remembered reading it somewhere in the literature, why it was off is a strange one though and why even include it, turn on the new valve, everything should work, why an oven shutoff at all ? Thanks for the correct answer...............
  • Anonymous Mar 30, 2014
    igniter glows for over three minutes but doesn't light until a burner is turned on also oven will not relight when baking
    President:
  • Kenmore Master
  • 2,651 Answers
I would look into the valve/regulater at which you connected the gas line, off to the side or somewhere on the regulater itself there should be a shut off for the oven control, simply flick to open positon and you should start right up. it would shut off gas to oven but allow burners to light.
Posted on Oct 19, 2008
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 07, 2010 | Maytag Kitchen Ranges
Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
Sep 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
New igniter, still won't work
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Nov 06, 2008 | Hotpoint RGB745 Gas Kitchen Range
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
179 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
