Question about Gateway GT4022 PC Desktop
Won't boot up
Computer crashed and won't bootup.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
Buy a new harddrive and install a new OS on it
make sure your old harddrive is disconnected
after the new hard drive is working properly then reconnect your old harddrive and
u will have all your files back unless the old hard drives crashed completely
Posted on Oct 21, 2008
My HP 8020N is beeping with some blue instructions, it crashes and beebs then repeat the same thing when trying to rebooth
You are experiencing what we affectionately call "The Blue Screen of De##h", which is causing the PC to crash and reboot in a never-ending cycle. There are a few things that you can try to fix the situation. The first, and easiest, is to press the F8 key during bootup and try to go to SAFE MODE. If you can do that, then you can go to SYSTEM PROPERTIES under COMPUTER, select the SYSTEM PTOTECTION tab, and click on SYSTEM RESTORE. This will allow you to roll the computer back to a previous configuration, since it is likely that the crash could be caused by a corrupted or failed update. If you cannot get to SAFE MODE during bootup, you options get more limited. Most PCs today do not come with a Windows Installation disk, so using that and booting in the REPAIR area is not likely an option. This leaves you with either reinstalling using the recovery disk set (if you have one) or with the recovery partition. The downside of these options is that they overwrite ALL information in the disk, meaning all of your personal files will be gone. What you CAN do if you have access to another desktop PC is to shut down you computer, remove the hard disk, and install it as a second drive on the other desktop. It won't boot to the disk, so it can't crash. But you will be able to see the file structure on that disk and can recover personal files to a USB stick or other external media before replacing the disk in your system and using the recovery method(s) described above.
Mar 05, 2015 | HP Computers & Internet
I have a Asus G73JH Windows 7 64 bit operating system. Frequently it crashes into the blue screen of death and subsequently when i try to restart it. I get the select proper boot option error. Upon fu
press F8 on bootup and select SAFE MODE. try to login and do normal things. if this works then this is probably just a driver or application issue. if SAFE MODE doesn't work, this is probably a hardware issue.
Start your computer in safe mode Microsoft Windows Help
Mar 27, 2014 | ASUS Computers & Internet
Windows file is corrupted and can not boot up computer
Hardrive is most likely faulty or your memory sticks are bad or not completely inserted. If you are able to turn on pc, press f2 or f8 as soon as it boots, then insert bios mode, change bootup settings for CD-ROM as first bootup device, then Hard Disc as second bootup device, then insert your windows installation disc or recovery cd, insert it, restart pc and run the disc to install windows.
Oct 06, 2009 | Dell Celeron, 300 MHz (2997D) Processor...
L20 197 model (celeron) laptop.
In 19 years of working on computers I've seen 1 bad Intel CPU and it still worked it just showed the wrong processor speed. I'd eliminate the CPU being the problem. Generally if you have a bare system with motherboard, ram, keyboard and video and they turn on the system is good. The video may cause a crash if it's bad somewhere in the bootup process going into windows but it shouldn't stop the initial bootup process. The area I would likely suspect is the hard drive. If the arm inside the drive that controls the heads is loose it can cause the drive to read sometimes when cool and then to start slipping and not read when the system is warmer. If you can get into the bios there should be someplace there to check your temperatures and voltages. Those might be a suspect area. If the power supply isn't delivering the proper voltages or the CPU is getting hot could cause problems also. I'd like to hear more about what you're seeing on the screen when this system fails to boot. Does is show the ram countup, system devices and hard drives as detected in the bootup process? Or is the screen just blank. When it doesn't boot does the hard drive light blink continuously?
Oct 04, 2009 | Computers & Internet
Hi my computer will only come on in safe mode wont go on internet and when i try to do anything it tells me im not authorised
You may have to resort to re-formatting your computer and restoring it to day one. You might have gotten a virus that hijacked your computer. One way to check is bootup in safe mode and try sustem restore. Also in the boot up page just after your bios boot, see if there is an option available to select called " Boot to last known working configuration"
Hope this helps
Sep 24, 2009 | E-Machines eMachines Desktop PC
Will not boot
It can have boot virus and when booting it finds your antivirus soft and if cant stop antivirus then calls "crash" screens, also sometimes real crashes heppened vith driver incompatible or incorrect parameter stored. If you have any LIVE Windows CD or linux boot from it anc check for viruses, also make disk check with disk utility. If not corrected windows must be reinstalled. If you havent try try "last good known configuration " from bootup screen, to call boot press F8.
Aug 03, 2009 | Toshiba Satellite 1805-S204 Notebook
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Emachine 3623 boot up??
probley computer crash ,dont say what system you using try getting a onther copy of windows opeting system put in you cd drive and should pick it up, if not go into boot sequence in bios and d-drive your boot up first it should give you fresh operating system and maual load the drivers for your hardware manual if it has picked up
Oct 05, 2008 | E-Machines eMachines Desktop PC
Gateway GT4022 PC Desktop Logo
175 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
