Question about Electrolux Epic 6500 Vacuum
Can't open my EPC 6500 Electrolux
Hi folks,
Could you describe in more detailed how do I open the top part to disarm the Bag Full Sensor? I am stuck after opening the side rubbers. Thanks.
  • d_dalton Oct 21, 2008
    I'm having the same problem -- trying to disarm the bag sensor and/or eventually replace the motor if necessary, but first cannot get it open. Have found several answers that talk about sliding the bumper off toward the bag end but have been unable to pry it off. Help!
  • bangjeha
    bangjeha Oct 30, 2008
    Thanks, I was already able to open it the next day after I posted my comment.
Hi, thanks very much for the response. I was eventually able to work the side sliders off -- they did not want to move!... Could you point me to where I could order parts for this EPIC 6500 Electrolux? We started having problems with it was used (not by me!) to vacuum up plaster dust so I thought I'd be needing a new motor, but don't know where to order one.
Thanks!
Posted on Nov 06, 2008
    Problem Solver:
  • 7 Answers
What you do is open the bag cover, then lay the machine on its side. Wedge a flathead screwdriver in between the bumper and the rear plastic guide. With a mallet, strike the flathead towards the bag cover. (The front of the machine.) Until the guildes come off. After both sides are done, close the bag cover and roll the machine so it rests on its back. With 2 fingers inside of the opening where the cord comes out, pull up firmly with the other hand holding the machine in place. TA-DAH.
I wouldn't bypass the bag sensor if I were you. It's there for a reason. It sounds like your control valve is out. Change that and your problems are over. Quick and super simple fix.
Posted on Oct 29, 2008
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Is the style c the right bag. The vacum cleaner only runs about 5 seconds before it says the bag is full.
If you have a 6500, the C bag is the right one. Try turning the dial on top of the vac to the smallest dot and see if the machine will run properly.
If it is still doing the same thing, take it to your Aerus/Electrolux dealer for repair. The control valve assembly (full bag control) needs to be replaced and I don't recomend that you try the repair.
Joe
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
With a new bag -after turning vacuum on, it shuts down
This vac is prone to a control valve failure with the exact symptoms you describe. There is a dial valve on top of the machine designed to regulate how full the bag will get. The valve which sits underneath the dial on the vac likely has a broken plunger and will need to be replaced. Take it to an AERUS Electrolux dealer / shop for an experienced tech to work on.
Sep 13, 2009 | Electrolux Epic 6500 Vacuum
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
Bag Full Sensor
Opening The Unit:
Remove the hose, open the door, and remove the bag. Making sure that the door is open wide enough, pull the rubber strip on each side of the canister toward the opening until they are completely removed. With a little shifting, you will now be able to pry open the top cover from the bottom. Remove the obstruction sensor hose so that you can completely separate the halves.
Note: If the strips will not move toward the front, the you will have to slide them off to the rear. You will need two screwdrivers to pry open the top rear of the unit far enough to release the back cover.
Locating The Switch:
The "trip" switch is located on the inside top cover under the power button. The trip switch is activated by the sensor valve next to it.
Aug 17, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Electrolux Epic 6500 SR series
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
Nov 27, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
178 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
