Question about AMC Multimedia AMW-M520BLK Portable DVD Player
Screen going off
Well the problem resolved its self. After charging and unplugging from ac the dvd player works fine. so guess the dollar I spent on it was a grrrrrrreat deal. thanks
0 characters
1 Points
Is not working any more
Jan 03, 2008 | Yamaha DVR-S200 DVD Player
How can i get a greenbrier 6 in 1 (dollar tree) remote to program to my Magnavox DV220MW9 DVD Player VCR Combo
been there... time better spent driving to walmart/target/sears and buying a name brand univerasal remote and saving your self 5 hours and lot of aggervation this is coming from someone who like yourself who refuses to give in GOOD LUCK
Mar 10, 2013 | Magnavox DV220MW9 DVD Player VCR
I have a durabrand portable dvd player and I can not get the battery to recharge. I have unplugged it from the DC in jack and the cord from the wall. Reinserted the battery, then inserted the AC adaptor...
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like,, to buy a new litium battery or a compatible one.
Aug 25, 2011 | Durabrand PDV-709
Just Loading - Bad Disc
Normally I would say clean the laser lens, but I actually had the exact same model with the exact same problem, and that didn't work. I was able to get mine to work sometimes by turning it off and on and unplugging it, but even after opening it up, re-lubricating the gears, and replacing a few capacitors near the reader, I never did find a permanent solution.
I guess this isn't what you wanna hear, but I think its an untraceable problem with the motherboard.
Mar 25, 2010 | Cyberhome CH-DVD 300 DVD Player
Lost ac adaptor
well look on the player it self should say some sort a input voltage they all very then goto radio shack or dollar store find that style charger watch for ac and dc voltage good luck
May 03, 2009 | DVD & Blu-Ray Players
i had the same problem. i found that two large hair clip worked (like the huge ones that use to keep long hair up with). i put one on one side and another the other side. couldn't stand to waste my 200 dollars that i spent on the product.
Mar 27, 2008 | Disney D7500PDD Portable DVD Player
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
My dvd player blinks
Try cleanning the lens in the unit with dvd cd cleanner which can be bought in any office surplus store make sure its for dvd there are two types cd and combo dvd?cd i recomond staples office supplies it is only 10 dollars cad
May 17, 2007 | Cyberhome DVR 1600 DVD Recorder
Toshiba DVD recorder problem
Generally, this problem is caused by bad sectors or other problems on the hard drive and can be resolved by going into the setup menu and re-formatting the hard drive. Of course, all recordings on the hard drive will be erased, so spin them off to dvd first. Be sure to have unplugged and replugged the unit immediately prior to going into the setup menu (don't try to record anything). If this doesn't work, no-one will repair this unit locally, as it must be returned to Toshiba's(TACP) depot for repair. Best of luck.
Feb 02, 2007 | Toshiba RD-XS52 DVD Recorder
AMC Multimedia AMW-M520BLK Portable DVD Player Logo
24 people viewed this question
Top AMC Multimedia DVD & Blu-Ray Players Experts
Are you an AMC Multimedia DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
