Question about RCA P52937 52" Rear Projection Television
32in. rca lcd tv GOES BLACK
When i turn the tv on, it stays on for 5 mins. sometimes less, then the screen goes black while you can still hear the sound. any solutions?
  • 905 Answers
This is the conversion IC chip , it needs to be replaced
Posted on Oct 19, 2008
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Tv problem
Check its horizontal output section circuit for any loose solder terminals. Resolder all suspected solder terminals by applying little more fresh solder. Replace the horizontal output transistor. If this transistor have some leak, it will overheat within minutes will shut down the picture.
May 26, 2012 | RCA 27F530T 27" TV
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
My tevion 17'' lcd screen goes black during use
using a flashlight is there any video still on the screen, perhaps the backlight goes out?
Aug 03, 2009 | Televison & Video
I have a RCA L32HD32D, will be on for 1 to 5 min. later goes off
check secondary power supply. check capacitors and apply fresh solder.
Jun 01, 2009 | RCA L32HD32D 32 in. LCD HDTV
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Screen goes black
Check and make sure the software is updated on the set.
Aug 19, 2008 | Televison & Video
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
RCA P52937 52" Rear Projection Television Logo
339 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
