Question about Husqvarna Garden
Replsce steering cable
Steering cable on my mower with out front deck and rear wheel steer has brocken. how easy is it to replace?
  • 48 Answers
This is really a matter of your mechanical abilities - what i think is easy may not be for you -
Posted on Oct 24, 2008
You need to replace the blade clutch cable that runs between the blade engagement lever just to the right of the steering wheel and the the spring to the idler/clutch wheel on the top of the mower deck. Over time the cable binds in the sleeve/cable jacket preventing the blade from disengaging
Aug 18, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to fix the toe out problem on my 2010 craftsman lawnmower?
Your gonna have steering rods called tie rods going to each spindle (wheel). Most lawnmowers dont have threaded tie rod ends where you can unbolt it and turn it in or out to achieve perfect alighnment. If its a larger expensive tractor you will find this and its a easy fix but most likely you just have a bend in one of the tie rods or on some cheaper models there could be a plastic bushing warn out causeing play in the front end.( Being able to slightly turn wheels without steering wheel turning) I would most likely say you have a bent steering rod or two... GoodLuck Ken
Aug 04, 2012 | Craftsman Garden
I was mowing and all of a sudden it stopped steering. The front left wheel moves when I move the steering wheel. The front right doesn't. I can move the front right without moving the steering...
Sounds like the tie rod has came loose or broke, look for a rod that connects the working wheel to the steering and then compare it to the non working side and you will be able to see what is missing
Jun 27, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the choke located on a craftsman riding lawnmower? 42" deck
the should be a cable near the throttle on the dash by the steering wheel. if not look at the carb there should be a sliding choke on the front of the carb..good luck
Mar 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 19.5 42 lawntractor, steering started clicking, then would nto turn wheel. Bar underneath unattached hitting ground. Do not know where it goes. How can I fix.
not a expert just trying to help,,sounds like you have two or mor problems,, first the bar will only go to one side of the front wheels,if it does not snap into place,you will have to replace the joint.,, the clicking sound maybe the steering unit sliping,,look down from steering wheel follow the shaft down to the steering gears,, they might be worn out.. hope this help you
Feb 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Steering wheel hub off steering rod
The shaft and hub are probably a taper fit & will require a steering wheel or gear puller to get them apart.
Apr 01, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
