Question about LG 50PC3D 50 in. Plasma Television
LG TV Model 50PC5D can't switch to HDMI1 or HDMI2
Hello. I just tried to switch my tv using the input button to go to HDMI or HDMI2 so I could watch a dvd, but nothing happens at all?
I watch a dvd last week and everything was fine. Now I have no way to switch between the modes on the actual tv. Does anyone know what might be the solution?
Cat
  • Anonymous Dec 17, 2008
    Same problem here
5 Suggested Answers
jerryg50
  • 1646 Answers
SOURCE: Grainy picture on LG 50PC5D plasma
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Posted on Feb 10, 2009
  • 541 Answers
SOURCE: PLUGED IN HDMI CORD AND I NOW HAVE NO SOUND THROUGH THE TV
Some of these sets have to run seperate red and white RCA cables along with the HDMI. I know it sounds silly but it is the truth. Look for audio inputs on the back near the HDMI port.
Posted on Oct 13, 2009
nostechjb
  • 28 Answers
SOURCE: LG LCD flickers and turns itself off
I'm guessing here.. most probably its the ccfl tubes..
Posted on Nov 15, 2009
  • 1039 Answers
SOURCE: Audio on HDMI(2) output with external audiocord?
The audio from the hdmi out on your computer is turned off. Try connecting another device such as a dvd player to the hdmi input on your tv . If audio works on tv then you know no audio is not available from the hdmi output on you computer.
Posted on Nov 21, 2009
dave1645
  • 834 Answers
SOURCE: LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Posted on Nov 28, 2009
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Aug 16, 2016 | Televison & Video
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
My p.s3 will not work on my 42 inch plasma t.v.i used to use an hdmi cable to watch it now im using a.v cords how do i reset or fix the settings it was on before?
Go to the main menu of your tv then try to select for the video input, you will see there the inputs tv or av1,av2, hdmi1,hdmi2 etc. try to choose the av1 or av2.
May 14, 2011 | Televison & Video
Put my ps3 on hdmi cable and now cant get it back to av . tryed holding the on/off button on for the first and second dong but still not back to av HELP
Welcome to Fixya. If you're using a HDMI cable to connect your Ps3 to your TV you need to set the input to HDMI. Use the remote of the TV look for Source or Input Button then change the Input to HDMI1 or HDMI2.
Thanks for using Fixya.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
Just installed my new 32le5300. Cant switch to dvd player. manual won't play on my imac. Can you help?
The manual is available as a PDF here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LE5300.jsp . Click on Support and then the Televisions Manual on the right. Just above is a link to Adobe Reader if you need the program.
LG doesn't always support Mac systems but that shouldn't change the manual access if you have a working optical drive. If you have Adobe Reader, then the problem might be that the disc won't autoplay. Try manually accessing the contents of the optical drive. (Open the File explorer and then the optical drive.)
Next: is your DVD player a stand-alone device or is it part of the computer? How have you connected the TV and the DVD player? The model number would help. Generally, you need to change the source for the TV to match where the DVD player's cables are going into the TV. There is a button for this on the TV's remote (and on the TV, just left of the power button) - labeled Input. The DVD player should be off when the TV is turned on and then set to this source. (The TV can get confused otherwise.)
The HDMI and HDMI2 ports should work with a PC connection (1920x1080 with the input label set to PC for the TV if you change the label for the HDMI ports). The entire list of inputs should be TV, HDMI1, HDMI2, HDMI3, PC (VGA), AV in 1, Component in 1, AV in 2, Component in 2, HDMI4.
I hope this helps.
Dec 30, 2010 | LG Televison & Video
No signal on HDMI1. Had to switch to HDMI2
Ur HDMI/1 might be shorted,will not work again.But u can tries unplug,replug the tv an hour later,let it reset it self back to factory setting.Who know might get lucky,it work again.
Apr 24, 2010 | LG 50PC5DC 50 in. Plasma HDTV
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
LG 50PC3D 50 in. Plasma Television Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
