Question about Rosen inVUE II Video Ent. Sys '00-'02 Chevy Suburban w/o Sunroof
1989 suburban k2500
Could someone tell me what could be the problem if theres a lot of white smoke and water out the exhaust pipe.
  • 55 Answers
Head gasket no doubt about it
Posted on Sep 27, 2009
Will a bad upper intake manifold gasket on a 97
sounds more like a blown head gasget a compression test will tell you for sure
Sep 25, 2014 | Cars & Trucks
Replaced head gaskets but still have white smoke out tail pipe
NOTE: Water vapor will collected in the exhaust system and will burn it off as steam until the pipes get hot enough to boil it off when starting a cold engine. That being said:
you could indeed have a crack in the head, or crack in the water jacket. You may or may not be able to spot some contamination of oil in the coolent or vice-versa, i would check for that too.
Dec 08, 2013 | 1989 Ford Ranger
I changed the turbo now white smoke coming out of my exhaust
This seems to be a symptom of a blown head gasket.
White exhaust smoke is an indication of water / coolant in the exhaust. The car running sluggish and using lots of fuel can be caused by compression loss.
Look at the coolant level color and smell (with cold engine - don't open the high pressure reservoir with engine hot as hot coolant may spray you in the face). If you have a blown gasket, the coolant color may become brownish and it may smell bad or the level will get lower even if you have just refilled the cooling system.
What you can also check for is bubbles in the reservoir. With engine cold, remove the reservoir cap. Start the engine. Try to rev the engine (or have someone do it) and observe if there are bubbles in the reservoir tank. If you see lots of bubbles, you have a blown gasket.
Dec 05, 2013 | 2001 Oldsmobile Intrigue
Blows white smoke out of exhaust pipe
White smoke can be as safe as water vapor being blown out of your exhaust system, or your engine is sucking tranny fluid out of the transmission, if it's automatic. Even gas can show white or grey out the tailpipe sometimes, that just means you are accelerating too hard.
Check your transmission fluid. If it is low, have a mechanic find out why, tell him what you see. Otherwise, no big deal.
Nov 22, 2013 | Arctic Cat 2004 400 4x4
Blowing white smoke out of exhaust pipe
White smoke is usually a sign for a bad head gasket. How much white smoke is coming out? Also, are you losing coolant and can't find a drip under the engine?
Nov 22, 2013 | Cars & Trucks
I have 1988 honda accord and it is emitting white smoke from the tail pipe (a lot of white smoke). can anyone tell me what make this happen.
White smoke comes through the exhaust due to leak in turbocharger seal.It can be solved by replacing the turbocharger kit.
Sep 03, 2010 | 1988 Honda Accord 4 Door
White smoke exhaust
White smoke is caused by coolant or water coming out the tail pipe. There is a chance that the white smoke was caused by water splashing up from a puddle onto the exhaust pipe. Keep an eye on the coolant level in the radiator in any event. If its less then there leak coolant leak in the car engine which is causing this problem....
Oct 18, 2008 | 1988 Isuzu Impulse
Thick white smoke coming from exhaust
White smoke usually associated with water or moisture. it doesn't take too much water to produce white smoke. check
1. cloudy oil under oil cap
2. leak through gasket from cooling jacket to combustion chamber
Oct 08, 2008 | 2000 Nissan Pathfinder
Car Audio & Video Logo
59 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
