Question about Philips 60P8341 60" Rear Projection Television
Blue Convergence Problem
We installed a new PTV small signal board to solve a power problem, but we have no blue convergence. The blue cross simply is not there although the blue tube is lit. It is not focusing. When I look into the blue CRT it is just diffuse blue light. We replaced the IC7003 per Philips recommendation but that did not help. We crossed over the focus leads from another color but no change to blue. Do you have a suggestion?
    President:
  • 3,130 Answers
See if the leads from the green crt Pcb on the green crt is long enough to reach the blue crt. If you hook up the working green circuit to the blue tube and it still dosent light up On the screen, then you know the tube is bad. Just a quick way to test crt's,. If it does light up then you have to trouble shoot the matrix for the blue tube. The drive maynot be vorrct the g2 voltage maybe not enough so then the screen block could be bad. I just wanna warn you against the very very high voltage inside these sets even when there not plugged in. BE CAREFULL PLEASE
Posted on Jun 14, 2006
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Blue gun jumped to right, and convergence adjustment ineffective
Your blue convergence amplifier is out and needs to be replaced.
Jul 05, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
BLUE ON THE MAGIC FOUSCE WILL NOT LINE UP
HI, normally when this occurs, this will signal a malfunctioning convergence chip that is located o the convergence board. this convergence board controls the calibration attempts when syncing the RGB streams.
Simply replacing the convergence board or chip will fix this issue.
May 15, 2009 | Hitachi Televison & Video
I have a blue shadow that outlines every image. the convergence of the blue cross does not seem to line up with the red cross as the manuel indicates it should. Also power has started to click off and on...
The problem is in the convergence system which can also cause the tv to not power up or intermittently turn on and off. About 50% of them are bad connections on the convergence power pacs. The convergence power pacs are easily located by the large heat syncs associated with them. The digital control board is located very close to the power pacs. Remove the circuit board housing the heat syncs and using high magnification look for rings around the pins of the convergence power pacs on the foil side of the board. Re-soldering up all the cracked solder joints in the convergence system including the digital control board should solve the problem.
If there are no cracked solder joints in the convergence system, or if repairing the connections does not restore the unit, the power pacs will have to be replaced. Ensure that you apply heat sync compound on the backs of power pacs or they won't last.
After replacing the power pacs, check all of the precision resistors for burn marks or detolerancing and replace as necessary. Next, although rare check the fuse links to the power pacs. This should complete the repair process unless there is some other atypical problem which is beyond the scope of this discussion.
Apr 27, 2009 | Toshiba TZ43V61 43" Rear Projection...
Adjusting the blue convergence on tv
1st. Go back over your soldering and make sure you didn't break a trace and joints are solid.
2nd. Make sure you installed the correct value resistors in there places.
3rd. I believe the blue crt is on your right, follow the convergence leads down to the board to the 4pin plug. Go from pin 1 of the plug to pin 11 on each of the IC's ( 1at a time ) with an ohm meter, when you see 0 or just about 0 that will be the blue IC, I have the PTV 915 manual that i'm using. I suspect you will find a mistake along the way. Take your time and double check everything again and let me know. Good Luck!
Feb 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
