Question about Hoover Elite Rewind Bagless Upright VacuumVacuum
Hoover Elite motor runs when moving backwards but not forward
Seems to be related to the angle of the handle since once in awhile it will start to run going forward but always runs going backwards
  • 1 more comment
  • gssummit Oct 19, 2008
    It used to always run the brush moving the sweeper forward or backwards just like most vacuum do.
  • gssummit Oct 22, 2008
    The motor shuts off when she moves it forward
    I have been an electronic tech my whole life. I feel it is an electrical problem but have not been able to find a schematic on the wiring.
  • 6,674 Answers
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Posted on Oct 18, 2008
  • Mike Butler
    Mike Butler Oct 22, 2008
    Does the vacuum actually shut off when you move it forward?
  • Mike Butler
    Sounds like a wiring problem down or near the pivot point. How handy do you feel?
I have a Upright Hoover Elite. Can't get belt back on right.
The belt loops over the motor shaft and the brush roller. Verify that the arrows on the end caps of the brush roller are facing DOWN or you will be doing the job over again. Start with the motor shaft and stretch the belt to allow the brush roller to seat. A new belt can require a strong pull on the brush roller to get it seated.
Nov 16, 2016 | Hoover Vacuums
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
How to replace on-off switch
Modern vac motors are polarized and cannot be made to run backwards. Take it to your local vac repair shop and let a professional repair it for you.
Jan 08, 2015 | Hoover Vacuums
Wont move forward or backwards
Generally the belt is probably stretched and needs replacing but I have had several that required modifying the height adjustment assembly. Belt should be a bit of a fight to stretch and get the brush block back in properly to maintain resistance. The higher carpet causes the belt to slip and can even cause burn/wear from the motor shaft spinning in one spot. Sometimes people run them and burn through and break the belt. Generally you smell rubber burning if belt is slipping and burning. The height adjustment modification was a last resort and not easy! Not for the average person! Another post tells how to modify but better be handy!
Dec 07, 2013 | Hoover Vacuums
Dirty water leaking? from cleaner.
1) you must test where is leak, for replace any hose or clamp tight , or repair some parts with Cool solder.buy it from any auto parts for fix it.
God bless you
Jul 03, 2012 | Hoover Floormax F5300 Upright Vacuum
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Flair motor shorting out?
There's a thermal cut-off when the unit has overheated. Mine does this quite often and I remedy it by emptying the canister and making sure the filter is clean, especially of lint and things that prevent good air flow.
Jul 07, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover Elite Rewind Bagless Upright VacuumVacuum Logo
257 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
