Question about Maytag MGR5729 Kitchen Range
F1 or A1 error
We may have possibly took a power surge and now our Maytag MGR5729 gas range has what looks like an A1 error on the display. buttons beep but won't do anything. The right side of the "A" is a little fainter, so I guess it could be an F1 error.
Thanks for ANY help.
SSmith
    President:
  • Maytag Master
  • 2,651 Answers
F1 is an error for the main control is faulty , replace the electronic control(clock w/ active overlay)
Posted on Oct 19, 2008
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
Display says E2 and F1
Hello there:
The F1 Error On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Now as far as the f2 this is regarding the temperature sensor that is possiably bad once you have the f-1 corrected this other code may go away but if it doesent then you will need to replace the temperature sensor of the oven ok
Nov 20, 2010 | Whirlpool GS445LELS Gas Kitchen Range
What is an F1-8 Error?
Hello there
First your f-1 error code
And the 8 error is also conclusive along with the f-1 meaning that the erc or electronic range controle is faulty and should be replaced
Oct 12, 2010 | Maytag MER6772 Gemini Electric Kitchen...
F1 locked on oven display and will not shut off
The F1 error code is usually for a bad touch pad or ERC(clock). To verify if it is the touchpad or the ERC that is bad you will need to first disconnect the power to the range. You will then need to open the back panel of the range to where the touchpad is located. Follow the ribbon connector from the touch pad to the ERC and carefully unplug it. Then verify that there are no wires that will ground and cause a short. Plug the power back into the range and then watch/listen. If you get a F-1 and a beep then the ERC is bad and will need replacement. If after 60 minutes you do not get the F1 error then replace the touchpad. A few of the Maytag models use a combonation touch pad and ERC as one. If that is the case then you will not need to verify if the touchpad or ERC is bad because they are one unit.
Jan 18, 2010 | Maytag MGR5880BDS Gas Kitchen Range
Maytag gas oven quit working
Sounds like the ignitor is bad. They get weak and stop opening the valve completely so it may cause the gas smell.
Sep 02, 2009 | Maytag MGR5729 Kitchen Range
Maytag stove burners work but oven won't
Check the electronic ignitor. Even if it glows it can be bad eenough not to open the gas valve.
Mar 24, 2009 | Maytag MGR5729 Kitchen Range
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Have Ilve oven but have misplaced the manual and we need to know the self cleaning program instructions
Here's the user manual for the Following Maytag Range Models (It covers MGR5710 • MGR5720 • MGR5729 • MGR5730 • MGR5755 • MGR5750) =>
http://shared.whirlpoolcorp.com/assets/pdfs/literature/MGR5710ADQ.PDF
Aug 10, 2008 | Maytag MGR5750 Gas Kitchen Range
F1 Error Code
F1 generally means the touchpad or ERC (Electronic Rage Control) is bad. This is what Maytag recommends as a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: - Disconnect power to the range. - Gain access to the back of the ERC (electronic range control, or "clock"). - Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide. - Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC. - Turn the power back on to the range. - Watch for the F-1 and listen for the beep. - If you get the F-1 and beep, replace the ERC. - If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad. NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control. I hope this may help you, but it looks like you may have an expensive repair. Double check your wiring just to be sure.
Jun 18, 2007 | Maytag MGS5770 Gas Kitchen Range
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Kitchen Ranges Logo
157 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
