Question about Sony Xplod XM-554ZR Car Audio Amplifier
Red light 2
I changed speaker wirers no diffrence, so no pinches in that area..... but it seems now i actually replaced my rca cords(new ones) and when i place them into the rear input slots of the amp, the protector turns red (with or without speakers on the amp).. also, since the spekers work on the front channel(but not alot bass, im guessing due to the high pass filter that i would mean somethings up with the amp... however, thats the way it should be right? if rca output from stereo goes to front input of an amp, and then sub hooked up to front amp output right? it shouldnt have alot of bass thru that? if the output on that channel is fried......would it be noticable if i popped it open? thank you for yur help.
    President:
  • 3,130 Answers
Probably not, as i said there are no user serviceable parts inside this unit. If the units worth it to ya take it in to be estimated. Good Luck
Posted on Jun 14, 2006
SOURCE:
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
Hi
http://www.livedigitally.com/2005/09/05/logitech-z-2300-speaker-system/
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Aug 26, 2011 | Logitech Z-2300 Computer Speakers
I do not know what color to use the RCA jack in
RCA Jacks are usually white & red for left and right speakers and yellow for video. If you don't have a three piece set - then they are probably just for speakers and its one for right speaker and the other for left speaker.
On the back of the tv, the RCA jacks plug into the incoming area - with the red & white going to the speakers right and left and the yellow to the video jack. Then you need to choose the input method on the tv menu set up that matches in the one you chose on the tv. Examples of input methods are AUX, Antenna One, Antenna two, ect. With the tv turned on - keep changing the choice of input until you find the one that gives you a picture.
Jul 17, 2011 | Samsung Televison & Video
I Just recently bought this have it hooked up to my Computer through a Digital audio Coaxial cord . The problem is this 600 - Watt system is emitting less power than the 300 watt one it replaced that was...
Audio power is relevant only between the amp and the speakers. Check the volume setting of the source and any audio settings in the PC.
SPDIF is not Red and White. If anything it is a single coaxial RCA connector.
Wattage specs for comparison are pure fiction at this level. 10% distortion fudges the number upward.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Defeat any bass enhancement in the source until you figure out the level issue.
Mar 23, 2011 | RCA RT2910 Theater System
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Similar prob.did the 12 steps on how to install amp(jensen4100,blue).red protec light comes on when starting car then goes out and is not followed up by the green protec light .green one never comes on....
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
May 16, 2009 | Jensen LXA300 Car Audio Amplifier
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
No sound when using the TV
1- Find the two audio out female RCA jacks on your tv. One is red one is white. Some older tvs may not have any, if so you are out of luck.
2- Purchase a stereo patch cord (male x male RCA) long enough to reach the LG's Subwoofer.
3- Connect the red and white plugs to the tv output and connect the red and white plugs to the "Aux In" female RCA jacks on the subwoofer.
4- Select stereo input for sound on the LG's user interface.
You will be able to upconvert the stereo input to various surrond modes by studying the control manual.
Nov 29, 2008 | LG LFD790 System
RCA 25204 - Line 2 red light
It probably means that you only have one line attached to your phone. Either the wall jack is only enabled for one line, or your phone cord is a two-wire cord and should be replaced.
Sep 13, 2008 | Lands Phones
I have a older Sony TV. I want to connect my magnavox dvd and older surround sound and my DISH network together. I need a diagram or step-by-step instructions as I am NOT literate to hooking these...
I will ilustrate how you do this .. first your magnavox dvd has a cord,has three defferent color of RCA jack yellow ,red and white,yellow is for video,red is for the rigth speaker and white for the left speaker. the video or yellow cord is input to the TV in the VIDEO 1 section the red and white cord is input to your old surround sound, next is your DISH network the output cord is going to input to the VIDEO 2 section in TV.. the video cord color yellow and the red and white to the is going to input in old surround sound, and the out of your old surround is for the speakers...if happens that your sound is one input by a Y RCA jack ,Y jack HAVE ONE INPUT and two output,,,feel free for asking question for further assistance in the future rate me a fixya.....
Jun 19, 2008 | Audio Players & Recorders
RCA F36685 No audio on cable channels
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
Sep 03, 2007 | RCA F36685 36" TV
Sony Xplod XM-554ZR Car Audio Amplifier Logo
79 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
