Question about Whirlpool GBS277PDS Electric Single Oven
Ran self clean on my oven and it stopped in middle of cleaning cycle
I ran the self clean on my oven and it just stopped in the middle of the cycle and it says E 1 -F5- and the door is loccked.How do I get my oven to work again. One time when a friends dryer read earer ,she was told to unplug her dryer for 15 minutes and then plug it back in again .She did that and it fixed the problem. I could not get to the back of the oven to unplug it ,but I shut off the power to the oven for 15 minutes and then turned it back on and it did not change anything.
Please Help
  • bwm2 Oct 19, 2008
    same thing happened to me with my Thermador. Can't get it unlocked. Can't pull it out of the cavity because screws are hidden by locked door. Guess I gotta use a crowbar and hammer!
    Genius:
  • 1,031 Answers
That most likely means there is a fault in the control board. You need to contact the manufacturer or retailer for service.
Posted on May 17, 2017
5 Suggested Answers
  • 5 Answers
SOURCE: The F5 error code?
Check here, Sharyl: http://www.repairclinic.com/0078.asp#Whirlpool1 F5 Check door/latch switch Replace switch if defective (or) F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel Depending on your model... -j.
Posted on Jun 19, 2007
fridgetech
  • 473 Answers
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Posted on Nov 03, 2007
  • 189 Answers
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Posted on Mar 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
How can I clean the pullout racks and side racks of self-cleaning oven?
The racks may have to be removed, if possible, and cleaned separately using oven cleaner.
Feb 18, 2016 | Ovens
I ran the self-cleaning cycle and now cannot open the oven door. Any instructions or advice?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
Jan 10, 2011 | Ovens
I ran a cleaning cycle on the lower oven. Now it won't heat
the answer is the thermal sensor, mine has gone bad everytime I clean the oven. Solution, run a fan on the oven while you are self cleaning, this keeps the outside heat away from the unit. Pain to replace the sensor, its in the middle back of the oven, have to pull the whole unit out.
Sep 24, 2009 | Whirlpool RBD306PD Electric Double Oven
Cannot unlock self-cleaning oven
I ran the cleaning cycle again, and it the door opened without difficulty.
Sep 13, 2009 | Kenmore Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
Oven wont come on
the oven door lock assembly has locked its self in to clean you can find the door lock assembly at the top of the oven where the door shuts sometimes if you push on the locking hook this will solve the problem
Dec 17, 2007 | Whirlpool RBS245PD Electric Single Oven
Whirlpool GBS277PDS Electric Single Oven Logo
42 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
