Question about Rio Go Video GV3080X VHS VCR
No power to GV3080X
I have a GV3080X dual VHS that gets no power. I have replaced the power supply fuse and when I plug the unit in, all I can hear is a buzzing sound coming from the power supply.
    President:
  • 3,130 Answers
Sorry but if a fuse blows theres a reason 99.999999999% of the time. as a fuse very rarly goes bad all by its self. This unit is a difficult one to trouble shoot unless you have the schematic diagram. It sounds like your missing the main b+ voltage and could be the regulator ic or a capacitor in the supply. If your not a tech you will be shooting in the dark replacing parts as you need a good muti-meter to assist you in these types of repair. Good Luck
Posted on Jun 14, 2006
Why won't my Panasonic DVD/VHS recorder repower after a power outage.
If it's that delicate, but you still want to keep it, you could try changing-out the mains fuse in the unit for a really, really low amps one.
You might be getting a power-surge as the power goes off, or as it comes back on. A very low fuse, might blow on the surge, which will leave you needing to replace the fuse, but not the capacitors.?
Best of luck.
Mar 09, 2018 | Panasonic Computers & Internet
Will not power up
Hello!
did you hear any unusual noises, while unit tries to power up? If yes, some gears might got out of timing or broken. If not, open up the unit and look for "bloated"capacitors in the power supply area. Find those? Replace with the same value and temperature ratings(105C). If not, surrender to local repair shop. Unless you equipped with "in circuit" capacitor checker and necessary soldering/De-soldering tools.
good luck,
Alex.
Jan 14, 2012 | Samsung SV3000W VHS VCR
Unit dead after a power outage replaced fuse blew fuse again even with power out of unit can i just get a new power supply?
Below is a link to a list of replacement parts for this unit.
http://www.encompassparts.com/models/?RCAVR605HF
The replacement power supply is $61.00 so probably not viable. 233160 CIRCUIT, POWER SUPPL [E3]
Depending on your technical ability if you could find which components have been damaged that are causing the fuse to blow it could be a very cheap fix.
If you require and further assistance then maybe you could post some pictures of the power supply PCB as I may be able to identify which components are damaged.
Please leave feedback
Cheers
Andy
May 10, 2011 | RCA VR605HF VHS VCR
Panasonic PV-4664 VR wont't power on. Replaced 1.6A input fuse and fuse blows immendiately when power supply is both installed and removed from the unit. Appears the power supply has a problem.
Fuses blow like that when a semi-conductor has shorted and acting like a piece of wire. Transistors diodes etc will show up quick with a Ohm meter, has it will be just like you have touched the probes together!
May 08, 2011 | Panasonic PV-4664 VHS VCR
POWERS OFF BY IT'S SELF
Hello FixYa customer,
There can be different issues in the mechanism or electrical that will cause the unit to shut down. However, since the power is going off completely after the initial plug in I suspect the power supply.
The SMPS, Switch Mode Power Supply has filter components that age due to heat, the voltage output on the filters reduces until the Micro Processor malfunctions and the unit won't stay on. The power supply filters can be changed by an experienced technician for $10-$15.00 in parts plus labor.
Thank you
Apr 23, 2010 | Sony SLV-R1000 S-VHS VCR
My Sony SLV-F900 VHS will not power on after power cut
If the fuse(s) check out OK, and the unit is showing no other signs of life I'd say you have a faulty switch mode power supply circuit - the best place to start is by checking all the electrolytic capacitors in it (look for any that have ruptured or are bulging on top and replace them with new caps of the same value and voltage if possible), then progress from there. Assuming the failure hasn't taken any other components out, re-capping may fix the problem but if the PSU has an IC regulator, it might be worth checking that as well. If it is shorted you may have to order a new IC which could be expensive (assuming the part is still available).
The faint sizzle would be the power transformer arcing as current passes through it. I believe there are no less than 10 caps in that circuit you need to look at. All electrolytic and all can be potential troublemakers.
You should only need to look at the caps in the power supply (replace any suspect/ruptured/leaky ones if necessary) as a starting point. If it gets too hard after that, consult a service center for a third opinion.
Dec 20, 2017 | Sony Televison & Video
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
My DeLonghi D14527DZ will not "power up"
FIRST OF ALL YOU COULD CHECK THE FUSE IN THE PLUG IF THIS IS OK THEN CHECK THE THERMOSTAT SWITCH TURN IT BACK AND FORTH AND MAKE SURE YOU CAN HEAR A CLICK IF NOT REPLACE THE SWITCH
Feb 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
CAN I ADD A TV TUNER TO MY DUAL XDVD8181 HEAD UNIT
just hook up a vhs or dvd player from home that has tv outputs, but you would need a power inverter for the power supply of the vhs, then put the vhs audio and videos outputs to the dual's input: the auxiliars. make sure the vhs has channel changing.
Jan 08, 2008 | Dual XDVD8181 Car Video Player
No power
Is it plugged in?? When was the last time you used it?? Did this happen after a storm?? What make and model of vcr?? How old is it?? We need more info if you want help on your troubles then it dosent work.
Apr 08, 2006 | Samsung SV5000W VHS VCR
Televison & Video Logo
60 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
SHARCNET-USA
SHARCNET-USA
Jaime Hernandez
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
