Question about Sony Xplod XM-554ZR Car Audio Amplifier
Red light so to further curiousity, or maybe just to pin the tail on the donkey, i removed all speaker wires, and the amp is a go(light is green) when i hook the sub up to the rear i get a pop sound then deadening of the amp(red light) however i did try placing the rear output of the stereo to the front in the amp, and placed the sub on the front outputs, and ti seamed to work.........(crappy since its highpass filter not rear speakers) is this conclusive that the amp rear output might be fried?
  • shawn bishop Jun 13, 2006
    i changed speaker wirers no diffrence, so no pinches in that area.....
    but it seems now i actually replaced my rca cords(new ones) and when i place them into the rear input slots of the amp, the protector turns red (with or without speakers on the amp)
    interesting eh?
    President:
  • 3,130 Answers
Have you disconnected the wire from the speaker?? and the amp?? Maybe the wire is pinched as I suggested?? If not then yes I would sy the peaker could be bad or the amp output on that channelis fried.
Posted on Jun 13, 2006
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Have issues with trailer lights. Both turn signals on trailer flash when I use left or right turn signal. Have 7 pin factory plug. Lights on trailer work fine, hooked up to 97 Silverado. Act funny on 2000...
Standard wiring colors are as follows:
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Jun 26, 2011 | 2001 GMC Jimmy
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
I need the wiring colour coding for the rear lights of a 2000 v40d as im fitting towbar electrics
Your post:
Hi There.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.
Good Luck
Apr 07, 2011 | 2000 Volvo V40
I need the stereo wire schematics for a 1995 ford aerostar xlt
1995 Ford Aerostar Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 5?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 3 1/2?
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
if you need further assistance please let me know. If this helped solve your problem then please feel free to rate it accordingly. Thanks, Midwest-tek
Aug 31, 2010 | 1995 Ford Aerostar
Have plug in towbar electrics for 52plate passet saloon need diagram to wire plug at towball
Hi There.
Good Luck
Jun 02, 2010 | 2002 Volkswagen Passat
WIRING DIAGRAM FOR TOWBAR ELECTRICS WOULD EXPECT TO BE COMMON BUT MODEL IS A 1994 MITSUBISHI PAJERO
Hi There.
Good Luck
May 03, 2010 | 1988 Mitsubishi Pickup
Fitting single towbar electrics, Hyundai Coupe 2.0 2004 (Tiburon)
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Apr 16, 2010 | 2003 Hyundai Tiburon
I need to find the colors for the rear speakers to hook up a amp
2003 Mercury Sable Car Radio Wiring Schematic
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 02, 2009 | 2003 Mercury Sable
Sony Xplod XM-554ZR Car Audio Amplifier Logo
76 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
