Question about Panasonic PT-52LCX65 44" HDTV
Clean filter HOW DO I CLEAN FILTER AND WHERE IT IS LOCATED IN TV
  • 2 more comments
  • ckpate Oct 25, 2008
    we have the same problem!! Where is the air filter located at? Where can we buy a air filter for our panasonic pt-52lcx65. We need some answers. thanks
  • angry_lil Nov 03, 2008
    I have the same problem. I think that I know where the air filter is. I just don't know how to go about cleaning it. If you pull that front piece off of the tv where you would find the lamp, look to the right of the lamp and there are two screws. If you remove those screws and pull off the cover you will find the air filter. What I don't know how to do nor do I want to try is to pull the thing out. I was thinking on spraying it down with air duster. What do you think?
  • champrodeo Dec 03, 2008
    my washer wont run. It hums but nothing happens.
    tonya champion
    903-388-5421
  • Anonymous Dec 13, 2008
    same thing???????
    Problem Solver:
  • 5 Answers
In order to clean the air filters properly. The projection unit must be removed from the rear. This unit is very expensive! I would recommend calling for service. But you can find the service manual online for free if you feel daring.
Posted on Dec 09, 2008
How do i fix a bissel not sucking
Clean the filters. Check your User's Guide for filter locations. Or, Clean the Water Tank Filter located on the tank Cap. Clean the Flow Indicator Filter Located Under the Flow Indicator. Hope that Helped.
Jul 23, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Tv is displaying to clean air filter, where is the air filter? How do you clean it? Does it have a reset?
Found on the net:
The Panasonic air filter is located BEHIND the removable Front Panel.....it pops off and you should see it located in a "screwed in" panel.
But, it MAY be located on the BACK or side.....LOOK for a Grille with a grey or black foam piece. IF you don't find it behind or beside the TV, then pull off the Front panel.
Now, those foam filters can be removed from the grille-plate to be washed......the best way to wash it is to PUSH the dust out of the filter by turning the Clean-side of the filter TOWARDs your water source (the faucet or the Much-preferred Kitchen Sprayer)....Now get that DUST OUT!
Once finished cleaning just shake all the water out of the foam panel. Snap it just like you're snapping somebody with a towel. Still Moist? Don't worry, the plenum on the TV is pretty long and "moisturized air" won't hurt the bulb......
Reassemble it......
And DO NOT let that filter go that long between Cleanings!! It EXTENDS the life of the bulb when maintained regularly.
Oct 12, 2010 | Panasonic PT-52LCX65 44" HDTV
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
A screen comes up and says time to clean air filter, Where is the air filter located?
I just experienced the exact same thing. The tv will shut off if it gets too hot, and a clogged air filter will make it too hot. My tv is still under warranty, but I watched the technician do it. He removed the front and back part of the tv. He got down to the bulb enclosure in the rear of the tv, which is where the filter is located. He used my dirt devil and a brush to clean out the filter and the whole general back of the exposed tv. The he put all the pieces back on the front and back of the tv. Hope that helps!
Feb 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
The check filter light has come on, where is the filter located on dryer dle0332w???
The lint filter is located right at the bottom of the door opening. Pull it up and out of the dryer. Clean the filter with a paint brush or with running water but make sure it is dry before installing it. It is recommended to clean the filter after every load to avoid the build up of lint.
Feb 14, 2010 | Washing Machines
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
304 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
