I have iMacG4. It has 3 hubs on back of pod. I switched to a wireless mouse. If the base is plugged into one of the three hubs on the back, the mouse works. If it is plugged into the Belkin 6 port hub attached to the computer, it does not work. If the mouse with the wiresis plugged into the keyboard, the sound works. Does this mean I have to go back to a mouse with a wire? I'm going out of my mind with this situation and am ready to throw the damn thing out. Your help would be gratefully appreciated.
  • 88 Answers
It depends on how the mouse operates.check the instructions to see what port it operates from.may not be suitable for the belkin 6 port.
Posted on Oct 18, 2008
    Sergeant:
  • 264 Answers
Do you get the sound even when the base is plugged in to the port at the back
I cannot find the wireless base to my wireless mouse and keyboard kr0401. Can I get another wireless base?
You can buy a wireless mouse and plug the dongle or base into a usb port . Most are Plug & Play so as soon as your pc starts up it should find the program on the wireless base unit and identify it for use . Try ebay.
Feb 02, 2015 | Gateway Computers & Internet
Toshiba Canvio 2TB USB 3.0... wireless mouse problem
Get a USB 3.0 Port hub at walmart or any place that sells electronics. They normally have 4 usb ports on the hub and that should allow you to have both the mouse and the hardrive running since the hub would be plugged into your usb 3.0 port on your computer.
Feb 25, 2014 | Computers & Internet
Hallo i can not get my new wireless mouse to work
Make sure the mouse batteries are fully charged.
Also make sure the mouse is not too far away from the base / cradle and there is nothing blocking the sensor on the front of the mouse cradle.
Make sure all the cables are fully inserted. Check both ends of the power adapter plug going into the back of the mouse cradle and the plugs leading to the back of the computer.
Try cleaning the little red LED light under the mouse with a QTip to remove any dust.
Make sure you restart your computer with the mouse cradle / base plugged into the mouse port.
Then be sure to connect the base and the mouse by pushing the button on the base unit, then the small button on the underside of the wireless mouse.
Also try using a different mouse pad. Some work better than others with certain brands of wireless mice. And also make sure there is not another wireless mouse being used in close proximity. The two can often interfere with each other.
Thank you and good luck.
May 22, 2011 | Saitek PM45p Wireless Notebook Optical...
Mouse pointer appears. but not working
Try to restart your computer. Since the mouse isn't working you will need to press and hold the power button. If the mouse is wireless, then check to ensure that it has good batteries or is charged. Also, if it is wireless, try pressing the button to "link" it to the base station. The base station will also have a button to push. If it is not wireless, check to ensure that it is connected to the computer. If it is connected to a USB hub and not directly to the computer, then try connecting it directly into the computer and restarting once again. Sorry to hear of this problem. Best Wishes!
Mar 28, 2011 | Computers & Internet
My mouse doesn't work with my mac for some reason. I tried new batteries and i tried putting it on my friend's mac and it worked and i tried switching the USB hub and still it doesnt work. it was working...
Try bypassing the USB hub and plugging the receiver directly into a USB port on the computer. Sometimes devices won't recognize properly if they're going through a hub.
Nov 25, 2010 | Logitech Cordless TrackMan Optical...
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Usb Trouble
The USB ports all share a single power source. It may be that the Ipod being added overloads the connections.
You might want to consider purchasing a USB hub, but make sure you get one with a Power Adapter to boost the current to your devices.
Oct 01, 2008 | Microsoft Wireless Laser Desktop 4000...
Wireless mouse and keyboard
Push the connect button on the wireless base, then push the connect button on the keyboard or mouse, that is supposed to reconnect the device. Make sure the wireless base is close enough to the keyboard.mouse, and nothing metal is blocking the path between the keyboard/mouse and the base.
Jan 25, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
