Question about Kenmore 92329 Electric Kitchen Range
F1 Displayed My range is displaying F1 and keeps beeping. I clear it using clear pad, it stops display it for a few seconds and then does it again.....how do I clear it for good, so I do not have to be annoyed? Please contact me with solution at my email address as soon as possible. carolbrandt@qwest.net Sincerely, Carol Brandt
  • Anonymous Sep 13, 2008
    F! error code on Kenmore model 911.936 9161
  • 641 Answers
Carol, The F1 error code could be cause a failed ERC(EOC,Clock assembly)or a faulty touch-pad. To check the ERC and the touch pad, follow the steps below : -Disconnect renger's power cable. - Gain access to ECR's back. - Disconnect the ribbon cable between the ERC and the touch-pad - Reconnect renger's power cable and switch on. - If you will get the F1 and the beep,it means that the ERC is fault and should be replaced. - If you don't see the F1 code and don't have the beep, you should replce the touch-pad. Good luck !
Posted on Jun 13, 2006
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
My F1 Code keep beeping.
I think you must post full information about your stove
Dec 06, 2013 | GE Kitchen Ranges
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
I have a tappan range that keeps getting F1/F3 in on the display panel.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
My oven keeps displaying the symbol "F1" and continuing to auto-clean
Try pressing the stop/cancel button, if this does not work unplug stove and wait five minutes and then plug back in, this should clear the display
Nov 16, 2009 | Frigidaire FEF366EC 30" Freestanding...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
What does error code f 1 mean on an electic range if i hit clear the beeping stops but comes back on in a few seconds
Copied from another website:
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jul 26, 2009 | Frigidaire Gallery GLGF389GS Kitchen Range
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Kenmore 92329 Electric Kitchen Range Logo
338 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
