Question about Whirlpool Duet GHW9150P Front Load Washer
F 24 error code
It is in the rinse spin cycle an code f-24 is flashing. what do i do
  • knot2kwik Nov 02, 2008
    I was attempting to wash a medium sized load of white terry cloth towels & rags. I used the "Sanitary" setting (Extra Hot-Wash, High-Spin, with an Extra Rinse). After the "3H" passed I went down to unload the washer & found the washer had stopped sometime during the Rinse Cycle, and was flashing the "F-24" error code.
    I followed the directions in the reply to the initial post (Stopped the washer, the turned it back on, this time with a "Normal" setting and the Cold-Wash.) So far, so good. I'm 20 minutes into a 58 minute cycle & all seems well.
    My question is, what went wrong on the "Sanitary" cycle? Did I do something wrong? To be on the safe side, do you recommend that I have a serviceman come out to check the heat sensor?
    Thanks for the assistance!
  • Anonymous Mar 12, 2009
    I have an f2 error code on my washer and it will not drain or spin, can I unclog it, and if so, how do I do that?
  • 1,122 Answers
F24 error code has to do with the water temp sensor,turn the washer off set the washer to cold only and start the washer for a reg. cycle this will confirm the problem,also you can check your water hoses are ok and remove the back panel to check the water pump that everything is tight,let me know how you do,mike
Posted on Oct 18, 2008
  • MIKE major Oct 19, 2008
    did you do what i said to do to confirk problem?also there is a error code tech sheet behind the lower front panel that will help you,i was hopeing for a fixya rating!!!!mike
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
Whirlpool Duet washer, during the wash cycle, get H F error code
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Jul 31, 2010 | Whirlpool Washing Machines
Model WTW6600SBO: Machine is stuck, won't spin
I'm having the exact same problem...did you ever find a solution?
Jun 16, 2010 | Whirlpool WTW6600SW Top Load
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
262 people viewed this question
Dan Webster
Dan Webster
Sal De
