Question about Pioneer DEH-P3700MP CD Player
Pioneer head unit plays in accesory mode, but not when vehicle is fully started
A buddy of mine recently bought a 93' geo tracker to run around in. the kid he bought it from hooked up an older model pioneer head unit sometime before my friend bought the vehicle. the problem he is having is that the unit gets power, but only produces sound when the key is turned to accessory mode, and no sound when the vehicle is started up. any ideas?
  • 15,935 Answers
He tapped into starter wire instead of accessory. Remove radio and verify the switched power (red) wire is properly hooked up to an accessory wire that stays on after vehicle is started.
I believe the wire is white/black behind the radio. Check with a voltmeter to be sure.
for the wire codes to that vehicle.
Posted on Dec 22, 2008
Wiring diagram 93 geo tracker
all last post was error, under GEO Prism the car is really
a 93 tracker, not that is much more easy
make sure you know what engine you have first. 8valves or 16v
as every other page is different by those 2 factors. (engine type)
most are here. (to make car run and lamps work)
yours is here.
page one here, may cover it.
the link is really just a large fuse. for A./C
did blow the main fuses. messing with battery or alternator or starter>?
on all cars ,before messing, pull the NEG battery lug first.
this prevents blowing out those big puppy fuses.
Apr 01, 2014 | 1993 Geo Tracker
How to put custom radio in 93 Geo Tracker
old post
go to walfart or any autostore on earth
buy the car radio adapter kit $10, for 93 tracker or Sidekick
plug it in and it works
easy huh> PNP , plug and ply magic of ADAPTORs.
if car was hacked, different long answer.
Feb 16, 2014 | 1993 Geo Tracker
Geo tracker problems
Does it get hotter if you just let it run without driving?
The thermostat you put in, did you make sure to put the solid copper side into the engine block and not the other way around?
Are you running water alone, or have you a proper coolant mixture?
Is the electric fan running all the time?
Sorry, need more info on this one.
Jan 08, 2014 | Cars & Trucks
Engine accesories brackets 1996 geo tracker
correcting an old post.
Do not listen to the guessing persons. this car is a V belt car. all are, by Geo 1.6L 89-98 (1.8L Suz, different car and matter)
the 96 tracker is a 1.6L SOHC motor,
they are sold with and with out A/C or P/S. "options"
so are set up 4 different ways, ( i have the full 96 parts list)
try this.
Mar 19, 2013 | 1996 Geo Tracker 2 Door
93 geo tracker will turn over but wont start unless you pour gas in intake then will continue to run until you kill it. will not start back unless you pour more gas in intake.
Sounds like something is letting the fuel pressure bleed off after the motor is turned off. Can you monitor the pressure? (Requires adapters and gauge.) Trouble shooting will be a little different between the 8 valve or 16 valve motors. (The fuel injecton systems are different.) You might want to go to a Suzuki Forum. (Your Tracker is a rebadged Suzuki.)
Dec 17, 2012 | 1993 Geo Tracker
Where do i put the engine oil in my chevy tracker
if you open the hood and look in it should be on your right hand side in the front part of the motor good luck ray
Jan 16, 2009 | 1991 Geo Tracker
Tranny clutch problems in Geo Tracker
well i have test.
if you have 1inch free play in pedal it clutch slips ,
clutch is bad , or the 89 93 bell housings are diffr.
was disk put in not backwards?
is it a new clutch.
Nov 19, 2008 | 1992 Geo Tracker
Pioneer DEH-P3700MP CD Player Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
