Question about HP vs15 15"LCD Flat Panel Monitor
Monitor going to sleep
Monitor turns on, on the reboot, but after about 30 seconds it says monitor going to sleep, then dosnt come back on. Please help!
    Genius:
  • 2,120 Answers
Click start...control panel...power options...set monitor to never turn off.
Also, you may have a bad backlight bulb.
Posted on Oct 19, 2008
This shows your computer doesnt boot....
if you are using an external graphics card.take it out of the motherboard and try restarting your system ....it may work up..this tell that there is a problem with the card...if it doesnt work...then check the ports that you are using for the monitor connection..if its a dvi port then go for a check with the vga port ..if it resolves the issue then it is a problem with the ports ...u need to check your motherboard
Posted on Jan 19, 2009
My Lenovo Thinkvision monitor stuck in sleep mode.
You may need to blow the dust out of the back of the monitor or get a new rebuilt monitor. They run about $30 at shops that rebuild them. Usually good will stores have computer stores attached to some of them. The computer store in Omaha is Called good bytes.
Feb 12, 2015 | Lenovo ThinkVision L192 19" LCD Monitor
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
HPw2338h screen is black and says going to sleep?
They usually go off when the don't detect a signal from the computer, make sure the connection is ok between them.
Jan 28, 2012 | HP Computers & Internet
Monitor going to sleep problem
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
May 30, 2010 | HP 2009M Monitor
I have an HP w2207 flat screen monitor. I have to
I stoped the monitor from sleeping by going into the montitor's menu, management, then sleep. Turn on the never allow to sleep mode. We were having some of your mentioned issues with the icons and with the monitor not waking up. This fixed that. Now the computer will go to sleep and when started the monitor comes on instantly.
Mar 23, 2010 | HP Computers & Internet
One of Two Samsung 204B Monitors Not Comming Out of Sleep
Hello Steve,
The problem is caused by a bad power supply board about to die. Check our web site at:
www.ccl-la.com/badcaps.htm We have a step by step repair guide for the 204B / 204T monitors that should get you back going. If you don't want to do the repair yourself we do offer a repair service for $30 + return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Aug 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Monitor goes to sleep after 30 minutes vl1919
Welcome to FixYa! The default power saving feature is turning the monitor off. To change the settings go to the Desktop>Right click on it>Properties>Settings and you will see power saving settings where you can choose "Never turn off" or a longer time interval. These settings can also be found in your Control Panel for all of the Power Saving features for the computer, monitor and hard drive. Steve
Jan 03, 2009 | Princeton Digital VL1916 19" LCD Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
HP vs15 15"LCD Flat Panel Monitor Logo
260 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
