Question about Goodman Heating & Cooling
I have a goodman acu model PGB030075-1A and it does not heat. The site glass is dark, not lit.
  • franci9936 Oct 18, 2008
    If you have an air conditioning unit and you dont want the gas to work you just want the heat to work like the other air conditioning units that have no gas, can it be done or your just better off with using what you got?
    Novelist:
  • 124 Answers
You can install a straight cool t stat that heats with the backup heat strip only. you can cool with ac only but using the heat pump reverse cycle will be a cheaper sourse of heat.have a pro look at it and give you some options. technology is changing so fast the best decision might be a new systemwith a new 10 year parts and labor warranty.
Posted on Oct 19, 2008
Why is my heated auto dimming driver side and rear view mirror getting dark when driving
Look in the fuse box for the fuse it will likely have other things on it but nothing to high voltage .
Pull the fuse and see what happens .
Honestly I have never heard of this .
Unless the mirrors lit or damaged somehow from to much heat damaging the coating on the back of the glass making it not a mirror any more .
This sounds like a factory defect
Feb 19, 2016 | 2004 Chevrolet Avalanche
Need a diagram of Goodman heat pump showing defrost relay area
Turn the power off to the heat pump and get a magnifying glass. There is probably only one board inside the outdoor unit anyway, but look closely through the magnifying glass and you should see a set of tiny needle size pins....maybe two rows of 4 parallel pins. There should be a black plastic jumper across a set of pins corresponding to the defrost length. Near those pins and written on the board there will be something relative to defrost duration. This is why you need the magnifying glass especially if you have any trouble with close up vision.
There is probably not a setting that is adjustable for the intervals between one defrost cycle and the next as they are typically initiated not on elapsed time, but on temperature of the outdoor coil providing input to the board that defrost is necessary.
Jan 08, 2015 | Goodman Manufacturing Goodman GPH1543M41...
Need glass pitcher for model No 54200
Possibly on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-GLASS-PITCHER-5-CUP-40oz-JAR-REPLACEMENT-PART-/161614412690?pt=LH_DefaultDomain_0&hash=item25a0f83b92. For an unused replacement try typing in your model number at HB's parts wesite located by clicking here . Check out the many www sites like abtecparts.com and goodmans.net. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Mar 15, 2013 | Hamilton Beach 54200 BlendMaster Blender
How to set time on model 13003
Hello
Get into this link. You can get all the details for your clock radio from there.
lib.store.yahoo.net/lib/partshelf/Acu-Rite-00592W-Manual.
Nov 17, 2011 | Acu-Rite Adagio Clock Radio
9000 BTU/Hr split type system, heat pump ACU, 230 Volts
It is 3/4 TR. Consumes 4.6 amps maximum and can cover of 80 sqft area with normal height of 8 feet.
Heat and cool model. Keep heat mode and +5 degree more in temp setting for heat and keep -5 degree temp setting and mode in cool. All the best.
Dec 26, 2010 | Heating & Cooling
Need a parts list for a goodman heat pump model cpkj 48-18
your best bet is to go to www.goodmanmfg.com make sure you have exact model # of your unit and if there is no help for you there then call the help line that this site gives you.Once you get the list of exactly which parts you need you can get univeral parts or order right from that site i gave you.approx cost about 300.00 hope this helps
Jul 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman model gmt090-3b ignator is staying lit all the time cause them to burn out .have changed board same problem.
Hi cannot find the problem for this but go to www.goodmanmfg.com
you can e-mail and ask them from the web page hope this helps
it could be the presure switch playing up
Jan 23, 2010 | Goodman GMS90703BXA Heater
Flame sometimes stays lit at the flame rod after heat cycle done
Definitly a gas valve that needs to be replaced and get another roll out switch after getting hot a few times they are demaged
Mar 25, 2009 | Goodman Heating & Cooling
Goodman heat pump
all waranties are different. check on-line at the goodman site and check your warranty info, on your model
Jul 14, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
117 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
