Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Continous ware flow on Honeywell HE220A Humidifier
I have installed the Honeywell HE220A humidifier. When the furnace cuts out the water continues to flow through the drain tube. As far as I can see it's wired correctly, ay least as far as the instructions go. Any help would be appreciated!
  • DIY_Disaster Oct 29, 2008
    I have the same problem. When I touched the sail switch, it stopped the water flow. I have my sail set for downward airflow. I took out the sail and found that the plastic flap once it's blown down, will not come up to stop the flow. (here's how it works: When the return air blow the SAIL down, the water starts running. When the furnace is off, the fan stops sucking in the cold air and the SAIL flap should go back up, and the SAIL switch will stop the flowing water). I wonder if I have installed the SAIL too low. The instruction said it has to be at least 15 inches below the horizontal duct. I have one round air duct coming in from outside that is lower. So I measure 15 inches from that duct. Therefore my switch is low.
    also, when I take out the SAIL and blow on the plastic hard, it stayed there after I stopped blowing. wonder if I have bad spring or faulty switch.
    please advise. Should I put the Switch for warm air supply? would the plastic flap last? Please someone ..somwhere must have solutions..or advices. Thanks in advance
  • M_A_T_H Dec 02, 2008
    I have the same problem and after taking apart the solenoid and noticing a pin hole through the valve body I contacted Honeywell support. Through subsequent emails and phone calls I sent them this picture where the white background shows up as a white dot at the center and bottom of the inlet port. A technician called be back and had me reassemble the valve and put it on humidifier. Everything checked out except water flowed continuously through the valve. He insisted the hole is supposed to be there.
    Although Honeywell support has been polite and responsive I doubt their technical prowess. I'm guessing there was a manufacturing problem where one or both of the ports was drilled too deep. This sort of problem should be fixed free of cost to the consumer.
    Miffed in Peoria
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Posted on Nov 20, 2008
    Problem Solver:
  • 6 Answers
The reason why your SAIL switch stays there after blowing on it is because you have 2 springs attached to the switch. If you read the instructions you need to take off one of the springs (silver color) when your return air is downward and vice versa with the red colored spring. You should only have 1 spring attached after a successful installation.
Posted on Jan 21, 2010
Is this unit design to have a continous flow into the drain? My flows all of the time.
Hello, the humidifier should only be running when the furnaces blower motor is running, therefore it should only drain when the humidifier is on and not flow continuously. Usually the humidifier will keep draining water when the solenoid is stuck open and should be replaced with a new solenoid valve.
Feb 04, 2011 | Aprilaire 700 Humidifier
HONEYWELL HE260
Unless you are using a current sensing relay or sail switch, you need to get the humidifier power from the blower motor supply so it only operates when the blower is on.
Since you can manually control the humidifier, there is not a fault with the solonoid.
Oct 19, 2007 | Honeywell HE360A1027 Whole House...
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
Jan 28, 2011 | Honeywell HE220A1019 Whole House...
I have a honeywell he220a humidifier . the water drips in but does not get the filter pad wet.
Open the waterline tap valve or may have to clean small orifice that is in line where 1/4" line meets humidifier. Need to shut water off and in screw nut holding copoet line to humidifier
Jan 22, 2011 | Honeywell HE265 Humidifier
Honeywell HE220A water not reaching humidifier
Replace the Valve on the unit. Check the small filter inside of it where the waterline attaches first. If its clear and you have lots of flow from the 1/4" line the replace the valve.
Jan 19, 2009 | Honeywell HE220A1019 Whole House...
Honeywell he220a install
thanks for your question,
you have to install the bypass humidifier on the supply side of your heating system, (hot side) and run a bypass pipe from the return side, (cold side), it does matter which side it goes on, you do not want water vapor going directly into your furnace, as this can damage it and shorten the life of it, your humidistat is installed on the return side of your duct work, this will allow proper operation of the unit as the humidistat senses the moisture in the air and brings on and shuts down the humidifier as needed. hope that helped to answer your question, please let us know what you think, again thanks, mr.grzz
Jan 17, 2009 | Honeywell HE220A1019 Whole House...
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell he220a waterflow
Sounds like you Connected the humid trans fromer directly to a main power source. It should be either on the EAC or HUM term on the board of the furnace.
Dec 11, 2008 | Honeywell HE220A1019 Whole House...
How does transformer hook up
if you just replace the unit and it is working, no your do not need the tranformer. The unit is getting power from the furnace. For reference though. The black and white wires are your 120 volts. Black hot, white common. the 2 screws are your 24 volts
Nov 25, 2008 | Honeywell HE260A1010 Whole House...
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
1,399 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
