Dead tv The tv powered off & a burning smell came from the set. I've inspected the circuit board & have found what appears to be a ceramic capacitor burnt. It is designated c335. can you tell me the value of it & will it be safe to replace it. magnavox mpf68b tv I found the same problem with capacitor 335. I am also wanting to know the value of the capacitor
  • Bunsa65 Jan 03, 2009
    I did some research with justanswers.com and they new nothing, A WASTE OF TIME AND MONEY. I called Philips in Australia, jackpot, answer is 1.8nf 2Kv
TRY TO RESOLDER THE CHROMA IC AND SYSCON IC
Posted on Jan 11, 2013
How come the on-screen channel display turns orange or blue instead of yellow ans I can't get any channel or play video - Sharp Mdl. 20V-S100 TV
Posted on Oct 13, 2009
Burning smell
Need the board locations of the parts your needing the info on. Such as cxxx or Rxxx stamped on the PC Board.
Mar 05, 2008 | Zenith H27F36DT 27" TV
After turning TV on it turns itself on and off
The problem is with the power circuit board components . The capacitors have gone bad. A pop sound is created due to the burn out of the capacitors..Faulty capacitors can be identified either by using an continuity tester or by appearance that i will be bulged at the top...
Most probably the burned out part which created the pop sound must have created a burned appearance in that area. Just check it out...
If you are an novice in working with the circuit board please take it to a technician who will be able to desolder the components and solder it again..
Feb 23, 2010 | RCA TruFlat 27F520T 27" TV
MY 63'' SAMSUNG SHUT OFF BY ITSELF AND DOESNT TURN ON ANY MORE,IVE HAD THE TV FOR 2 YEARS WITH NO PROBLEMS UP UNTIL YESTERDAY
Feb 22, 2010 | Samsung DLP HL-P5663W 56" TV
Power on
Feb 05, 2010 | RCA 20F512T 20" TV
I have a Hitachi 57in projection color television. The problem I have is that when the set is turned on there is a click but no picture or sound.
Ur DM power board is dead.Have burns capacitors,check for puff up capacitors.Buy capacitors parts for replacement to rebuild board.Tries thes websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Jan 30, 2009 | Hitachi 57G500 57" TV
Dead set, HOT transistor keeps shorting
It's the copper coiled magnet on the neck of the crt closest to the front of the tube.
Dec 21, 2008 | RCA 36V430T 36" TV
Sony kv 29x5d
Please mention correct model number to check C633 value.
My system recognise this model as incorrect.
Jun 01, 2008 | Televison & Video
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Jan 27, 2008 | Televison & Video
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
